drewpy
Everything posted by drewpy
  1. sorry black; we are going saturday as Man City are playing sunday weather forcast is SUNNY!!
  2. drewpy replied to hebrew hammer's topic in Classics
    I don't have any spare covers but there are some on ebay UK the tools for changing the seals are a spring compressor ( not a car one as its too narrow to go over the cyl head) and torque wrench. you can make a compressor with a G-cramp welding a castlated bit of pipe to take out the collets like this you will need to follow the haynes manual as it gives you how to progressivly undo the head bolts to prevent warpage. I'm going to have to do mine as up.yours spotted smoke from my left side ( on a 1000 mile rebuilt engine) its a simple procedure and you need patcience and don't force anything. All i used was the haynes book to do it! drewps
  3. just keep the same bore as the 400, unless going dual disk, then you would need a larger bore Master cyl. TBH any bike master cyl will work as all it does is push fluid pressure to the brake pistons, just in different amounts depending how many pistons need pushing hope that helps drewps
  4. I wish I had more time-weather-bikes-money etc etc looks great there!! drewps
  5. you need to get the brakes checked
  6. drewpy replied to drewpy's topic in Video Section
    could put pedals on 350lc's as well
  7. to the forum. ditto the ditto on the avatar!!
  8. http://www.megacyclecams.com/catalog/page57.pdf http://www.hagon-shocks.co.uk/main1st.htm I've seen prog front springs on ebay, try "Wurth" mainly from germany, but I'm sure you can get them in USA. HVC cycle may have them high rpm on idle is too lean a mix and either compensate by richening the idle mix on the carbs or they need a good clean( pref ultra sonic) I'd try ebay for gaskets, partsnmore do them for $45 drewps
  9. yep you'll need to bleed the brakes. simple enough if you've already got some fluid in there. there's loads of "how to's" on interweb drewps
  10. its an xs400E taper bearings in head stock is good. bronze bushes in swing arm hagon rear shocks progressive front springs megacycle cam reprofile also google "minton mods" its for xs650 but is good for 400's as well as for oil weep, you need to clean the engine and see where the leak is. it could be a rubber seal. drewps
  11. drewpy posted a topic in Video Section
    <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  12. you need a good allen key and a bar extension to overpower those buggers
  13. have you retro fitted drum brakes, so you have a bowden cable?
  14. tell us the chassis number and we'll tell you!
  15. keep the forks and springs together and get your allen key( this fits a bolt underneath the bottom fork leg) and quickly turn the bolt. If you are lucky it will snap undo, if your unlucky it just turns the "inner bits". you can try and compress the forks by pushing the top tube against a wall and try turning again! Failing that, another way is to get a wooden dowel ( 20mm x 500mm I think) chamfer the end by about 5mm around. you then have to take out the fork spring and whack in the dowel which should engage in a cup lower inside the fork leg (the bolt is holding this in) grip the dowel and then undo the bolt (it will be very tight) hope that helps drewps
  16. drewpy replied to new lc owner's topic in The Bar
    so your sorted now?
  17. the contacts do earth out as that is what they are supposed to do, but this is via the coils to complete a circuit and then release it to discharge the primary coil. I'mm assuming that the bike runs ok? The other issue I could suggest is the switch gear is faulty and needs stripping and cleaning/checking. the starter button contacts and engine stop are common and it could be there. did this fault just manifest itself or did you do something to cause it?
  18. drewpy posted a topic in Video Section
    Wouldn't it be nice to somehow trick fatties into taking more exercise? <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  19. drewpy posted a topic in Video Section
    Order one From Me & You can Get A Free Pearl Jam Neckless <object width="464" height="338" alt="Hilarious Shake Weight Exercise for Women Funny Videos" ><param name="movie" value="http://embed.break.com/842424"></param><param'>http://embed.break.com/842424"></param><param name="allowScriptAccess" value="always"></param><embed src="http://embed.break.com/842424" type="application/x-shockwave-flash" allowScriptAccess="always" width="464" height="338"></embed></object><br><font size=1><a href="http://www.break.com/index/hilarious-shake-weight-exercise-for-women.html">Hilarious Shake Weight Exercise for Women</a> - Watch more <a href=" Videos</a></font>
  20. drewpy posted a topic in Video Section
    classic chune....ish <object type='application/x-shockwave-flash' style='width:683px;height:404px;' data='http://www.rathergood.com/plugins/content/jw_allvideos/players/mediaplayer_4.3.swf'>'>http://www.rathergood.com/plugins/content/jw_allvideos/players/mediaplayer_4.3.swf'> <param name='movie' value='http://www.rathergood.com/plugins/content/jw_allvideos/players/mediaplayer_4.3.swf' /> <param name='quality' value='high' /> <param name='wmode' value='transparent' /> <param name='bgcolor' value='' /> <param name='autoplay' value='false' /> <param name='allowfullscreen' value='true' /> <param name='allowscriptaccess' value='always' /> <param name='flashvars' value='file=http://www.rathergood.com/content/agamemnon/agamemnon.flv&autostart=false&fullscreen=true&image=http://www.rathergood.com/content/agamemnon/agamemnon_thumb.jpg' /> <param name='id' value='myplayer' /> </object>
  21. only Alex can do this and as he is inbetween flats/adsl it may take a while
  22. drewpy replied to peterb's topic in Yamabyss
    if private get it serviced, dealer should do it as a matter of course ( well I would have got them to)
  23. sounds like sacrelige to me
  24. where's the pictures, WE WANT PICTURES!!!
