drewpy
Everything posted by drewpy
  1. Yep. arrow forward and torqued to 7lbs ft ( 10 nm) in cross pattern. mines never leaked there ( elswhere is a differnt story )
  2. drewpy replied to RenaatXS's topic in Classics
    some faves of mine and i posted a racer in the video section which was LOUD!!
  3. yep thinking of going, weather better be good
  4. I was busy yesterday, buon compleanno Foams
  5. no, i said you can use the xs1100 master cyl! the brake lever is irrelevant as its just a replacable part and common to all yam bikes of the era. you need a left caliper and mount for the dual system, check the caliper pictures as some had a swinging caliper which is different from the floating caliper which I think you have!!
  6. drewpy replied to root's topic in Yamaha Workshop
    what was the oil like when you changed it. this will give you an indication of wear. ie did the last owner change the stuff
  7. let us know what you decide to do BH250. http://www.rschrome.co.uk/index.html this was the one I used http://www.classicsandchrome.co.uk/1.html
  8. Jordan you can use xs1100 master cyl and left caliper and mount or if you can't find the left side stuff, SR500 caliper mounts on the left side. I tried the T pipe route but couldn't find room on an xs400 so used dual banjo on master cylinder ( no, not deer hunter music ) drewps
  9. drewpy replied to Stev125's topic in The Bar
    gallino vechio
  10. drewpy replied to root's topic in Yamaha Workshop
    if you've just bought the bike, get a manual and service everything (should do that anyway) check timing, cam chain tension and valves. that way you get to know the bike in your own time and not at the side of the road (especially in the middle of nowhere) and you have a bike you can trust. good luck drewps
  11. moo do you have a fuel filter on the bike? did you check the pet cock and clean? how old is the battery, with electronic ignition you NEED good amps and volts anything under 12.5 is asking for trouble. check charging with multimeter and it should read 13 - 14 volts @ 3k rpm. a duff battery will give the symtoms you describe! drewps
  12. i feel sick
  13. Kin'ell doesn't suprise me
  14. cool, i was thinking of doing one for the scouts, but the nearest track is 3 sisters and I'm not sure how much use they would get out of that. its a great project and well done!! drewps
  15. contact Motad, I'm no exhaust specialist
  16. cool ride, i think the q you need to ask is "what is the width of the the swing arm mount" if it will fit your frame width, the rest you can make fit I'm sure! drewps
  17. drewpy replied to drewpy's topic in General
    your welcome
  18. XS400SH model you can get an offical manual. 20w 40 over 5'C is listed for that model drewps
  19. .....or is it!
  20. two golfers were on a putting green when a hearse drove by. one golfer took his cap off and bowed his head. The other golfer was amazed at this act of respect and told him so! "its the least i could do for the wife" he said
  21. midrange and higher
  22. its on the headstock
