Everything posted by drewpy
Just got an XS 360
but not here 1L9-24181-00-00 DAMPER,LOCATING 1 XS360 C 1L9 4 left $14.55 http://216.168.60.165/speedandsportinc/Index.tpl and here http://www.pgmyamaha.com/mk109.html
another bike!!! (old bike)
just had to sell the missus cg last year, cracking little bike. there's a web site on it but I deleted it after it sold! I've also seen a cg chopper
Peter Rabbit
another bedtime story to go with the happy tree friends DVD
Just got an XS 360
should do no can do with the xs range need power to excite the field coil. if you ditch the starter, you could get away with a 4amp battery
bloody pilot screw
I'll have to grind down a nail and knock the tip through the body. not the best, but the only way
bloody pilot screw
Putting back together my carbs after having them vapour blasted, the pilot screw has yet again snapped off in the carb body. damn damn damn there got that off me chesticles
neutral problem
obviously adjust the clutch as that may be dragging also try adjusting the final drive chain, as that helps too!
Need help identifying this song!!!!
just about to say that!
Just got an XS 360
you don't need to undo the cover. pop off the rubber bung on there and you will see a 10mm nut and screw slot. get a box spanner and slacken off the nut, with the screw driver through the box spanner lightly tighten,then back off 1/4 turn. holding the driver tighten the nut so it don't move. replace the bung slack at the clutch lever = 5mm drew
- A simple appeal
VIRUS ALERT
http://urbanlegends.about.com/library/bl_postcard_virus.htm
Howdy!
wondered who was poking? to the YOC
A simple appeal
a picture of the tent would be useful Jim and the link don't work!!
Just got an XS 360
I'd say you need to take off both carbs and strip them down. get the manual in the sticky as it will show the different parts in the carbs. clean the outside first, then strip 1 carb at a time, and clean using carb cleaner and compressed air. strip down the brass parts and make sure you blow all orifices with air and cleaner. all it takes is a little specs to cause problems. run carb cleaner through all the carb galleries. its not too hard except for undoing the cheese head screws on the carbs!! use an impact driver if you have to ( but carefully) you can do this in an evening. id also fit an inline fuel filter in case there is crud in the fuel tank.
Just got an XS 360
you've woken up from your hibernation OT? nice to see you again
Check it out peeps, brings back memories...
that's been on ebay for a while
- intro
Just got an XS 360
shit in the right carb, try spraying easy start in the carb and see if it fires ( or dump some fuel into the cylinder)
1981 XS400 with a charging porblem. (Heard of that?)
try and steal/beg/borrow another battery of good provenance and see if that helps. i had my bike get slower and slower comming from a rainy long ride and switching off my head lamp helped. turns out it wasn't charging ( 1 month old battery) a new quality battery (yuasa) cured it! drewps
Idle issues
this has been done to death on this forum you either have a dirty carb pilot system or an air leak on the inlet stubs
Computer Security?
- apple iPAD
<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>- carol vordeman - spells it
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/watch?v=0vPN_33n3rM&hl=en_US&fs=1&"></param><param'>http://www.youtube.com/watch?v=0vPN_33n3rM&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=0vPN_33n3rM&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>- jihadist's buy bomb making equipment
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/watch?v=RYfYkO00-JU&hl=en_US&fs=1&"></param><param'>http://www.youtube.com/watch?v=RYfYkO00-JU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=RYfYkO00-JU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>- Suspension Upgrades
wurth progrssive front springs and new fork seals of course hagon rear shocks, the business - apple iPAD
