drewpy
Everything posted by drewpy
  1. I wonder it can be luminwelded! its a low temp ally repair solution
  2. here's a handy resource https://macshot.de/rd/brakediscs.html all the patterns you will ever need
  3. rather than mess with spacers and a new calipers etc, i want to see it rideable and then i can redo the swing arm later when i get bored again. just got my gas cap and bung today, so sending off the buck to my tank builder tomorrow and it should be ready in 2 weeks i hope i got my measurements right, i did recheck them 4 times
  4. good idea
  5. nice seat and tail RDog, homemade?
  6. 2 totally different bikes, gladyou found your niche. I would have gone for the FZ meself
  7. drewpy replied to bznchris's topic in Yamaha Gallery
    I had my classic Series V Sunbeam Alpine done in Mercedes "dunckle grun" as the BRG stuff in the 80's was too light!
  8. drewpy replied to mervin's topic in The Bar
    that'll be Jethro then
  9. that would do it methinks. let me know how much you want for the spare? inc P+P (PM me) cheers
  10. drewpy replied to Goff's topic in FAQs
    you were trying to post an image from a website and I think that these are barred from all forums as it may break copyright laws or whatever. try imageshack like Vez says or I use photobucket
  11. i would say you have an inner tube. If the tube is old, i would renew it. I usually change my own tyres as I buy off t'internet M&P do innertubes (expensive P+P if bought on own)as well as ebay. check that the spokes havn't punctured the rim tape inside the wheel. it would also be a good time to check spokes anyway for tightness ( tap with a screwdriver and they should all sound approx the same) drewps
  12. pic would be great mate.
  13. seat is in the background and you can see the damage as white. the battery is a 2.1 amp 12v alarm battery which only needs to power ignition, lamps and charging circuit. chopper boys have used a .8amp cig packet sized battery i their xs650s!
  14. don't take off that pin, its only a pin but is solid in there. In your picture, the first thing i see is the brass washer, pick that out! now re-screw in the brass bit but loosly and give it a little tap and the nozzle should drop down. looks like you'll be busy cleaning that crappy carb
  15. how many "f*ck'n 'ell's" can you utter <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  16. what's the date for uttoxeter, i went the first year and it was ok!. I thought the best small show was lotherton hall near Leeds!!
  17. no probs len, we're going saturday 24th. I'm in Eccles and OT lives round the corner. eccles is only down the A57 from warrington!! drewps
  18. Howdy, I need a longer side stand for my xs400 tracker and was wondering what the length of a DT or XT would be? (measured from pivot to bottom) mine is 200mm and needs to be 250-260mm in length. not sure of the shape, but mine's like a fork at the pivot with a thread to take the pivot bolt! cheers drewps
  19. I think he's too pished to read this BJ
  20. so that's an xs400 then assuming the carbs are off; the nozzle is removed by taking off the diaphram and needle, then take off the float bowl and floats. Undo the main jet screw and the nozzle will fall out through the diaphram end!
  21. rock on Tommy and to the forum
  22. drewpy replied to bznchris's topic in Yamaha Gallery
    nice one chris, i did reply in your other post, but what is with the side stand, i need to extend mine for the tracker and need another 50mm!
  23. did a bit more fabrication today. built me a new battery box and looked at mounting the seat but chipped the bugger, so will need a little repair
  24. nice one dan and to the forum your most welcome to get more involved and contribute, or even ask a question!
