drewpy
Everything posted by drewpy
  1. drewpy replied to Turbo2ol2's topic in The Bar
    daaveee from hold'em
  2. drewpy replied to Thanasis's topic in The Bar
    thanasis nice intro as Paul says
  3. http://www.files.pioneerx.co.uk/index.php?dir=Motorbike%20Files/XS360-400 if its a haynes you want, give yamagod a PM as he is the one who uploads them. look here for your model
  4. set the floats to 26mm top of float to underside of gasket (carb up-side down). tried 32mm and it ran awfull. get a carb kit( keyster) make sure its the one for your year of carb as they can be slightly different. then fit the needle valve and while your at it the other jets etc. also check your pet cock is switching off when the engine is off as it uses vacuum to operate a diaphram drewps
  5. and greetings qrzysieq nice bike can you have a look at your engine number and post this please? the manuals in pioneer X still work.
  6. drewpy replied to JBennett's topic in Classics
    check the number on the locks, as the key should fit all of them. yam should be able to get you one.
  7. drewpy replied to Honeydo's topic in The Bar
    NRP in Manchester uk
  8. http://www.youtube.com/watch?v=H3ogYg05e_Q gives you all the info you need
  9. I ended up in the cavalcade last year and got a great parking spot in the paddock just tagged along after the last bike went past. if weathers good I'll be going
  10. and you have a girlfiend called Julie. just don't ask John
  11. drewpy replied to exess4's topic in Classics
    to the forum exess4 have a ganders at the sticky at the top of the classics section as there are loads of information there for you to read up.
  12. drewpy replied to Honeydo's topic in The Bar
    try here
  13. just bought this tonight. its a WW11 aircraft 3 position switch which I'll use to turn on the lights
  14. :lol:
  15. drewpy replied to rupie's topic in The Bar
    why don't you subscribe then?
  16. drewpy replied to drewpy's topic in Video Section
    All i could think about was the different positions I could try with them ahem!!
  17. drewpy posted a topic in Video Section
    <object width="640" height="385"><param name="movie" value="http://www.youtube.com/watch?v=BNR74UCidBI&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1"></param><param'>http://www.youtube.com/watch?v=BNR74UCidBI&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/watch?v=BNR74UCidBI&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>
  18. ifd that was the case, there wouldn't be 6 on there, more like 10
  19. drewpy replied to rupie's topic in The Bar
    here it is, good job i can remember! http://www.taxdisc.direct.gov.uk/EvlPortalApp/ another route you can try
  20. they all fall over
  21. drewpy replied to bznchris's topic in Yamaha Gallery
    I'll try to do some scans when i stoke up the scanner with some coal
  22. just got this email from Frost looks good http://www.frost.co.uk/item_Detail.asp?productID=9559&frostProductName=HotCoat%20Powder%20Coating%20Gun&catID=&frostCat=&frostSubCat=&subCatID=
  23. drewpy replied to Paulwhite's topic in Yamaha Workshop
    you need to key in the chrome. i've used a flapwheel in an angle grinder then wet and dry then used an etch primer. I'm sure I read somewhere you can use muratic acid ( used by chippies for vinegar) and electricity to strip the chrome.
  24. drewpy replied to Rev's topic in The Bar
    enjoy your ride and to the forum
