drewpy
Everything posted by drewpy
  1. self cancellors are £45
  2. o ring part # for european bikes= 93210-29196
  3. yep, clutch out i'm afraid
  4. Grafton there is a xs400 with an xs750 tank on youtube wurth was his name http://www.youtube.com/watch?v=Owwd19VDbpg #2 have you tried the petcock on prime position and fuel is flowing?
  5. you can still buy the complete neutral housing. it tends to split being plastic! there is a ball bearing at the clutch end of the pushrod, so i'm not too sure if it will be drawn back into the engine when the rod is pulled. the rods usually rust near the seal causing the seal to fail, so you may need to renew the rod as well.
  6. drewpy replied to hobbo's topic in The Bar
    check the status here
  7. drewpy replied to quickchuck's topic in The Bar
    yep my friend. pull up a chair and have a drink............
  8. drewpy replied to a post in a topic in The Bar
    kevin and perry thunder, thunder thundercats
  9. drewpy replied to a post in a topic in The Bar
    If she starts complaining just keep revving the bike and pointing to your ears that you can't hear her! it looks like its going to be a hot summer, so you timed it right there matey!
  10. for a cool $35,000 you can own one of these the wheels are custom made 22" x12" dual hubless wheels with custom made tires The frame is 2" cold rolled and boxed hardened steel with carbon fiber/fiberglass bodies. Accent colors are neon glowing from behind frosted plexiglass and can be turned off or on with the flip of a switch. its on ebay now
  11. really you should ask the vendor, then, if it requires jetting the onus is back on them. i would say they don't need rejetting
  12. taken out the circlip on the left hand side? its under the black boot
  13. ollie looks good to me, I have that style of fender on mine although its really for the custom models as mine were the more squared version.
  14. they are off a custom version methinks as the pipes swoop more, the 2a2 models are more straight down at the front.
  15. just an exhaust stud. I replaced mine with stainless and aero nuts (reusable lock nut) if you just want ferrus steel, the're pretty common and don't have to be yam.
  16. drewpy replied to friedegg's topic in General
    well done FE great feeling, it gets even better now....
  17. nice one, glad to help
  18. it was on the one i looked at, the casting blocks it off anyways
  19. right had a looksey; the diaphram has two layers between which the plastic sandwich plate is positioned. the groove/notch is some sort of pressure release thng to stop air being trapped and preventing the full travel the O ring at the tip of the piston seals the gas in. the notch is where the vacuum spigot is which is facing up when mounted on the tank hope that helps
  20. drewpy replied to drewpy's topic in Video Section
    He he we should make our own up!!
  21. drewpy replied to 2 Wheels's topic in The Bar
    My mum lost hers about the same time, but Jess was like ours as well, so I can know what its like. She was a rescue dog and still miss her just remember the good times and the little/daft things they did that made you smile!
  22. drewpy replied to racewaypark's topic in The Bar
    tassles on the handlebars
  23. drewpy posted a topic in Video Section
    here it is folks, the officail yamaha chune from OG's day <object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=7lYz0WH-1vI&hl=en_US&fs=1&"></param><param'>http://www.youtube.com/watch?v=7lYz0WH-1vI&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=7lYz0WH-1vI&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  24. I'll se ya sunday then, drive safe and don't sniff too much of them stinkwheel exhausts you know what it does to you
