drewpy
Everything posted by drewpy
  1. need to look at this Pat
  2. usually theres a tiny circlip deep inside the body. Its been a while since i did my carbs and the laetr carbs are less easy to work on!
  3. drewpy replied to oldtimer's topic in Yamabyss
    silly billy!
  4. I had a new tank but got it professionally stripped of rust etc here I then did the coating myself, its easy enough and you can do a better job.
  5. I would look at your battery. if its even the slightest way down, it will affect the ignition. the electronic ignitions need a healthy (ie good amps) battery and the battery is also used for charging! (sounds odd but true)
  6. try clearing the tiny hole within the master cylinder its a return orifice for the brake fluid
  7. drewpy posted a topic in Classics
    stunning looking bike, clicky pikkie to sitey
  8. used that stuff on me tracker tank, stinks a bit (still does) but sorted!
  9. Hairy specs!
  10. have fun John and ride safe. There was always a lots of scots in Blackpool, especialy when it was their holiday weeks. lets see you on the big one
  11. I've looked at the chain link too and just go for heavy duty standard chain and keep it oiled. for £22 I'm not going to bother with anythiing else!
  12. why are you posting this in the bar? workshop would be more appropriate and did you do a search on bleeding brakes? we have another member having the same issues (abet a different bike) but its all relevant!
  13. did you earth out the light blue wire near the neutral switch? if the lamp didn't light its either a live supply problem or, as said, the bulb has gone and needs replacing!
  14. short intro would be nice as a first post
  15. I'd start collecting parts for the bike when your on your travels. I personally wouldn't try and start the bike until at least I had the head off to check for rust. With the added ingredient of the turbo! those need a lot of tlc in my opinion and it might be worth checking the bearings (and pricing up for a refurb) good find though foams, the yam version of Top Gun
  16. drewpy replied to burkejt1's topic in Yamaha Workshop
    sounds like it needs a tune up! and maybe a new battery
  17. Andy, when buying for your 250, the 360 and 400 models are identical frame wise but make sure they are SE as that model has a slightly longer stantion. You may also want to check out Wurth springs based in germany! (via ebay) drewps
  18. sounds like hot stuff Mmmm
  19. scratch 'em and buy a new set, i'm due new for this year!
  20. as merv said, but you need to remove the final drive cover to unhook the cable. The black "plug" needs jemmying out with a flat bladed scewdriver. Gives you a chance to clean all the crud, check the front sprocket and the charging wires for damage! make sure the cable has the easiest path to ensure its smooth operation. I just fitted a new one last week and it was so light in operation as opposed to the old one.
  21. warming up for weekend, John, why not stay overnight? there's a free day out on the 8th at Northwich thundersprint. danny webb, Jim Redman,Cal Crutchlow etc etc will be there. Its about an hour and half from Blackpool! http://www.thundersprint.com/latest_news.html
  22. just perusing t'internet and came across these peeps http://www.blackandwhitebikes.co.uk/lightweight-motorcycle-battery if there is enough interest i recon I could get a 10% discount for YOC members!
  23. don't lose interest with this bike will you Foams? should be a good build and if you have a spare turbo, I'll take one for my xs
  24. to the YOC
  25. to the YOC
