drewpy
Everything posted by drewpy
  1. now i'm confused, you said there was no spark in your first post. so you now got a spark now and there is another problem? is there anything thing else we should know?
  2. ebay, make sure they are for either contacts or electronic ignition!
  3. Rf (right fire) Lf (guess) no flywheels on the xs, you just remove the left cover (4 allen bolts) on the centre stand and the oil won't come out! tip; if you over fill the oil, you can get rid of excess via the side stand method!
  4. drewpy replied to Michael's topic in Classics
    not sure where you are from but electrex world do a combined unit
  5. try rk leighton covered my xs seat for £20 with leather supplied.
  6. Ladies and gents I give you.... Spinal Pat
  7. drewpy posted a topic in Yamabyss
    I liked this My link
  8. congrats on another year Merv
  9. scary stuff
  10. BP7-ES is the one listed
  11. If you look at the wiring diagram, the pints earth the coils which have a red/white positive feed via the ignition switch. ther is also a condesor to prevent sparks across the points, preventing arcing (sparks) which will erode the contact surface. the time the contacts are closed it powers up the coils in primary coil and when the contacts separate, the built up power in the coils has no where to go so passes to the secondary coils and jumps the spark plug gap (the easiest earth path). thats why HT leads are well insulated, stopping any earth leakage. hope that sinmplified explanation helps.
  12. drewpy replied to Michael's topic in Classics
    the regulator may not work for that type of charging system. It could be for a permenant magnet one! have a ganders at your earth connectins too
  13. glad I couldn't make it in the end. Better be back to normal next year!
  14. try the float bowl too, there is a passage way there too!
  15. nice one, looks like she's riding an xs
  16. drewpy replied to drewpy's topic in General
    I think you are right....
  17. get a battery! check fuses by removing and cleaning the glass fuses. no power as such across the points its a ground for the coils.
  18. drewpy replied to 78caferacer's topic in Classics
    what's the question again?
  19. have you put the O rings back the correct way? mikexs describes the way they go in in the advert for bs34 carbs
  20. I would dsay its an earthing issue, check all black wires from the signals and clean frame around them.
  21. presumably its an xs400! the carbs need a really good clean, ie strip and all the orifcies clear, use berrymans or seafoam and blow through with air.
  22. here's a scan
  23. wait till you see the rest of the bike.... anyway
  24. in weakens the mix! the slow to return to idle usually means its weak. If when it is warm, what is the response like then?
  25. cheers fellas
