drewpy
Everything posted by drewpy
  1. drewpy replied to 78caferacer's topic in Classics
    sounds like the rings are worn and air is being compressed in the crankcase.
  2. drewpy replied to barkwindjammer's topic in The Bar
    :lol:
  3. amazing, fantastic, cutting edge, these are the profane words of wisdom by BWJ when he first tested the POWER GLOVE see for yourself and be in awe at the amazing 8bit graphics
  4. drewpy replied to Paulwhite's topic in General
    you can get it done yourself Pat
  5. get one from yamaha, it fits real good 90506-28100 is the part number
  6. looking good so far mate, nice shiney hub have you waxed it to preserve the shine?
  7. can you not get a hook inside the hole and pull it out? it will wreck the filter so its a bit of a do or die senario. but you'll have to do it sometime. If you can take a picture it will help for more suggestions.
  8. some gud 'uns there
  9. drewpy replied to Paulwhite's topic in General
    for a tenner, count me in medium please! don't forget postage on top peeps
  10. didn't realise you had electronic ignition, I think you need to look at the TCI box first. drop speedshop a PM as he can give better advice on these things! BTW those are plugs and would need to be drilled aout and behind there should be screws.
  11. very nice mate
  12. aye but have your looked closly at the tail section?
  13. drewpy replied to Paulwhite's topic in General
    black's a good compromise. maybe when the price is in, we can have a vote using the poll system on here!
  14. dim headlamp is usually earth connection or lack of it. the castrol stuff is for bikes and its no problem on chrome.
  15. drewpy replied to Paulwhite's topic in General
    oldwankeronabike how's that? Paul, get a quote first for say 15 t-shirts with what you want on there (It looks pretty much there now) and put it to the forum. Peeps will commit more if they know how much.
  16. drewpy replied to Paulwhite's topic in General
    the front badges should go on the left tit! you can use the cloth badge graphic I did if you want Paul, was only pulling your plonker! not sure about the big yam logo on the back, too American for my liking! I think you should all have your forum names on them, woosies
  17. drewpy replied to 78caferacer's topic in Classics
    presumerbly just use bloke (i assume its black) and red, use a 12v battery to see what the other wire does!
  18. he's too busy muff diving off the coast of Manchester. hopefuly he'll come up for air soon. HB to vez anyway
  19. to the forum ST There's quite a bit to polish on an xs400 (SOHC), this is where you start a restoraion as you clean one bit up which shows up the rest of the bike. The next thing, its stripped down into bits awaiting cleaning!! For general bike cleaning, I got recommended the Castrol bike cleaner for Halfords, Its got acid in it and it works a treat. I just picked up some xswheels (the make, and its appropriate to have xs branded products on me bike)and I'm sure it has the same contents but cheaper. Drewps
  20. if you click on this link, you can find all the part numbers you want http://www.cmsnl.com/yamaha_model8287/
  21. drewpy replied to Paulwhite's topic in General
    I'd be interested mate. You have to pay me royalties on the design though Just for comparison, I got 24 t-shrts done last year for scouts and they cost £10 each. logo on front and a patch on the arm. Individual logos might be prohibitive price wise. I'll pin the post Drewps
  22. drewpy replied to Luc's topic in Classics
    sounds like a ground(earth) problem and the earth is running through the lamp. or the switch is knackered lighting the lamp up, just disconnect the front and rear switches they are easy to get at. You sure its a jack plug?, they are used for guitars etc, prob mean a multiconnector. For condensors, there are two but they are joined together in a single body, I think you may be refering to the self cancelling unit. It can be disconnected which just means you have to cancel the signals yourself.
  23. use a socket, or do you mean studs? two nuts together real tight should get them out,or if replacing, weld a nut on them or use a stud extractor (about £15)
  24. yep, there was nothing there anyway
  25. tadpoles and blackpool rock
