Everything posted by drewpy
Vic Berger Presents.....
To welcome back the new forum, thought I'd jolly things along with this...... clicky here
Thinking of changing my user name
do they not have one of those diagnostic ports on the electrics? they also use the tacho to obtain codes for troubleshooting
Y.O.C. 2018 meet,
talked yourself into that one mate. If you can post the route/s then at least we all have a chance of meeting up
Y.O.C. 2018 meet,
TDM is alive and well now. Who is leading the ride outs? can we have an itinery so at least when John and Kev get lost they have some chance of finding their way back
picking up a TDM850 Mk2 saturday
bit of an update; fitted the refurbed wheels with a larger tyre and also a new rear disk. Also fitted the refurbed front disk using original hub. I think I mentioned the saga of the fuel dump into the engine, well I've rebuilt the carbs (even having to helicoil one top carb thread). new inlet manifolds as the old ones were cracking, new throttle cable as I have to cut the old one off. The new throttle cable was a bugger to fit at the carb end as there are so many tubes attached to the carb. reset the TPS as it was out I balanced the carbs after replacing the oil filter and new oil. the bike runs a dream now, even better than before, the clutch cable was very slack but after tightening up seemed no issues and in fact changed a lot better than before. the enfoced fuel in the oil must have flushed the crud out of the engine. no knocking noises and jobs a good 'un
Y.O.C. 2018 meet,
what time are you finishing? I'm out for 4:30 usually, and can load up/check the bike day before so I'm ready.
- Forum will be down Monday
Y.O.C. 2018 meet,
I'll be there friday evening, might have to go on the FZ as the TDM decided to dump all it fuel into the engine. ordered carb bits and new intakes from Wemoto which aparently is coming tomorrow. you never know, just won't have satnav capabilities. there's another place called the bike hospital "Regular Saturday Bikers Hub. Start or finish your day at The Bike Hospital with free brews. 9am until 7pm (or later) EVERY SATURDAY RAIN OR SHINE Snacks and even bacon butty's are available. Car park is big enough for 100+ bikes. Meet new friends or bring your own and then go for a lovely ride in the Peak District.(Snake Pass, Woodhead Pass etc) Remember to do a free tyre pressure check when you visit. Further details, please contact Danie 07728702965" https://thebikehospital.com/
NC500 trip
saw the photos on faceache, very ingenious. My mossy repellant came today so here's hoping I don't get bitten
New to bikes
- the phone!
can you see link now? can't seem to get the embed on the page anymore- WTF.......ALECCCCCCCCCCC!!!!!!!!!!!!
tnx Alex- XJ400S Starting issues
thank feck for that, your driving me nuts with all these Q's ?- the phone!
- Drewps running the Manchester 10k
hip is really painful, everything else is fine mate- Drewps running the Manchester 10k
https://www.relive.cc/view/1584652365- XJ400S Starting issues
or carbs need a clean inside. spray your easy start around the intakes and if the revs rise because it it, there's a leak so you need new intakes. otherwise it might be best to send your carbs away to be thouroughly cleaned inc jets. I've used NRP in manchester as they are close to me.- XJ400S Starting issues
if they are dry, no fuel, carbs may be sticking shut of full of dried/stale fuel. keep spraying some easy start in the air box and if it sort of starts, its the carbs- Drewps running the Manchester 10k
mananged it Guys, was very tough as the temp rose to 30'C♨️ The start, empty pen, sson to be filled with 4000 runnners China Town met some guy from darn sarth, running for RMCH its getting full finished and knackered, get quite dizzy with the heat but didn't pass out thanks for your donations (if you haven't you can still donate)- BELL Custom 500
I like the Bell helmet, had one back in 2006 and was quiet and looked great. the full face are ££ though- XJ400S Starting issues
Have you checked the valve gaps and timing? no1 piston @ tdc should see both valves closed on #1and trigger on alternator just at the ignition point might also be a weak spark = no spark under compression- FJ1200 3CV new chain + sprocket advice
I've got the X chain via Afam and found it really durable. think i've adjusted it twice in 3k- My project
you'll need a respring for ou weight, prob about £100- Oh no bought a Honda 1978 750
- Blowing exhaust
nothing useful due to lack of information and say hi in the new members section - the phone!
