Everything posted by drewpy
Who's you favourite riding legend?
- Who's you favourite riding legend?
I thought I was your legendary rider tommy?- 1979 Yamaha XS750S Engine problems !
try a bit of choke and see if it helps. Its not really a choke but an enrichment device so your adding fuel.# could be that the carbs need cleaning as with all old bikes- XS250 Newbie
welcome trodd, local lad too. where a bouts in mancunia?- White wires to regulator/rectifier YX600
white wires are the output from the alternator to the rectifier, doesn't matter which way they are as they all output the same! if you have a manual the wiring diagram should give you the info.- Gilera 4V project
damn and blast, had the day off today to build the bottom end and the crank with bearing on won't go in the case without a press. I've tried heating the case and freezing the crank and it didn't work I've asked kev if he knows any one in the Bolton area who could do it but if anyone local to me (manchester) can do it let me know cheers Drewps- How about GTA V!
never fancied Assassins creed played tomb raider, the old versions. I did try and play dead space but it got really tedious after a bit, and then I tried S.T.A.L.K.E.R. which was great at first then the shit AI kicked and and the bugs and made it unplayable.- How about GTA V!
I love Portal, Bioshock and Half life. these are more my games. I first started with Doom 1 and was hooked ever since. Can't play any consoles though it has to be PC, just can't work out the buttons!- Improve my XS250 disk brake?
I fitted a large disk and blue spot caliper off an xjr1300 to the tracker if you wanted to go that route- Drewps new toy
- Fz600 Gulf
no oil contamination as I checked that! maybe the valve guides got cleaned out- Bikesure Competition Time
47 I think it was. well done anyway nice to win something- XT500/SR500 Wobbly sprocket fix
cool mod, pain to work out though!- Bikesure Competition Time
cnut tommy, it was between him and me who were the only ones to actually send a PM and not post in this thread- Ultimate Biker Footwear!!
gets rid of toe jam at 50 mph- Drewps new toy
- Drewps new toy
- Ride of Honour 2013
was it all motorway?- jacks o2 mod
just bi this 1 http://www.ebay.co.uk/itm/260961310339?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D260961310339%26_rdc%3D1- XS400 Flat tracker
you just use google and You'll find my how to http://www.xs400.com/forum/showthread.php?t=4730- XS400 Flat tracker
well I think I have finally found the leak. I smothereed the bike in talc and went for a ride. If I ride up to 40 then there is no leak, continous riding at 50+ gets the Torre Canyon treatment on the back wheel. After faffing replacing every seal I can think of, it's coming from the stater area. As I have put my ignition switch opp the starter motor, the oil at the bottom gets flung up, I put a baffle there to prevent most of it travelling, but for some reason, its throwing more up. this then gets into the hollow where the starter is and drains through the drain hole right where the chain it etc and then it sprays everywhere. Ordered a core plug the same size as the hole and I'll grommet it for the ignition wires and that should be that! I've ringed the drain- Fz600 Gulf
bloody hell, the carbs flooded again only because I filled up the tank, so I think the spring on the fuel tap diaphragm is a little weak! problem this time is the bike sounds like a bag of nails and runs shite. All i can think of the fuel bore washed the bores and broke a piston ring. I'll have to strip the top end and do that porting job earlier than I thought. looking at a gasket set on eBay ATM but I know it won't be done till march next year now as I want to do the Gilera.- Improve my XS250 disk brake?
i fitted a twin disk on my xs400 as fitted to the xs1100 and 750/850. uses the same caliper design it did stop on the proverbial dime and could even lock up the front I suggest a caliper strip down and M/C rebuild as they should be good stoppers! - Who's you favourite riding legend?
