Everything posted by drewpy
Crankcase sealant
I used an oldie called wellseal, they used them on the brit iron. you apply with a fine brush either side and let dry, no squelching out between cases as the other sealants do
Fz600 Gulf
sorry Tommy, nothing like what i'm after. Its all in the numbers mate I've tried every combination of my numbers into google and germany/usa have them but at over £100 ouch!
Project 86 FZ600 - "Black Yamba"
Oh a clarinet player eh?
Really frustrated at running engine in
buy it off him Tommy, you need a project
Fz600 Gulf
with this "new" engine I got, Yamaha decided to upgrade their engine to digital ignitions which are not compatible with the FZ system. Hence I am after an Ignitor marked tid-14-78 3km-01 I can also use the tid-14-79 3lt-00 as I have been assured that that will work too. Anyone got one for cheap please? any working alternatives would be nice too eg fzr600!
Are my Alpinestars GP Pro gloves fake?
https://www.catalyst-findit.co.uk/index.php?c=03860a9239e3aa1a8b94be6f5796b331&preview=6&dest=prod&p=400&pid=35567310%20S they're from 2006 so you may not find much else online
easy to google http://www.agriandgarden.com/valve-grinding-paste.html?gclid=CLGqz73S2LsCFUzHtAodvmAAfQ 1) clean the valves in situ with brass brush in drill 2) take out valves 3) you can also clean valves in drill if dirty, but watch your not reducing the valve stem width 4) grind in valves to seal with linky posted above
I thought it was just showing a photo, bloody 'ell Grouch!
Gilera 4V project
Bob Wright has just emailed me to say the final parts are on their way, yippee have the frame and fork legs at the local TIG welder to make a better job than me. Get the frame to the powder coaters next week and then should be on the final build
leave the valves in and get a brass wire attachment for the drill and decoke the heads. the vales need to be out to check the seal between valve and head (pock marks, bits missing) otherwise you can lap the valves in with grinding paste. you can get a kit of two types of paste and a little suction cup on a stick to spin the valve around to grind them to the head. don't forget to use your cardboard to put the vales back in the same order.
the wind has broken my bike
chill factor-e roof has blown off twice now, so its not surprising bikes get blown over
Hi from sunny Cape Town
got family in Capetown, in fact 1 works for cape fruit export
brake fluid is supposed to be good at gasket removing too according to classic bike mag
when i rebuilt the xs I put mineral oil in and rode like I stole it. dropped the oil after 20 miles and filled with semi-synth. this theory is the bores get bedded in and this worked really well. the only caveat was that i reused the good parts so essentially, they had their "edges" knocked off and I could do that. with a totally brand new bike, you got all that broken off shite lurking in the gearbox etc and cane-ing it won't do the bike much good recirculating it around the engine. I'd drop the oil and put new in and then think about giving it some
Are non Yamaha discussions allowed?
what was the question?
probably, you have to understand that its a 600cc engine in a 400cc frame. very tight for room
MOT Fail... b*llocks :(
get the green solid tyres, no punctures
i would have taken off the large nut on the adapter and kept the thing whole. But that's academic now. remove all electrics first (including that neutral wire) and alternator/starter wires
I'd keep it intact as you disturb the seals otherwise
save Brighton speed run
not from the area, but it's a legendary event and now the council want to ban it FFS register your complaint here http://present.brighton-hove.gov.uk/mgEPetitionDisplay.aspx?ID=410&RPID=11175561&HPID=11175561
I have had a great biking Christmas
wow, nice one/ Look forward to seeing some more on this and the openface with gigs. Got a NOS goggles despite its glass (laminated I hope) should be up for some longer touring escapes then?
horn button for my yamaha rxs 100
depends, the Rd xs650/400's go regularly and I'm sure Merv has a stash or get them from ebay
Owners Club Decal
don't hold your breath, still waiting for the 2014 calendar
some bargains at argos
JAn sales will start soon and maybe you'll get some xmas money off someone!
- ITS CHRISTMAAAAS
