drewpy
Everything posted by drewpy
  1. it also depends on the handle bar shape. American bars tend to have higher, curvier bars so there are shaped to meet those curves. TBH so long a the bore size is the same, you should be ok. try xs650 stuff off mikes XS
  2. drewpy replied to Cynic's topic in The Bar
    I never forget undoing a cam cover bolt on the FZ using a ratchet ring spanner. going great till it hit the frame with no where else to go. had to cut the spanner with an angle grinder. I feel your pain
  3. I'm suprised its finicky then. I'd still check timing, fuel height, valve clearance . before you start on different jets. BTW fuelling the top end still applies, get that right (over 3k) there' usually a transition around there from pilot
  4. check timing if its adjustable first. check 2 stroke oil as too much weakens the mix you need a jet kit, allens or NRP, you need to ensure mains set first for WOT, do plug chops to check mix. I assume the carb is set up and cleaned throughout?
  5. the xsr looks great
  6. I would check fowlers parts fiche and see it its labelled there
  7. drewpy replied to jimmy's topic in The Bar
    on the carpe-tdm site, one really tall guy has slightly modified his controls and this helped http://www.carpe-tdm.net/ipb/index.php?showtopic=37015&hl=tall#entry376858
  8. drewpy replied to jimmy's topic in The Bar
    my tdm850 is tall. I have a Hagon shock on though which does raise it a bit. have to lean the bike slightly to put foot down.
  9. usually an earth fault. strip and clean
  10. Irish Karl.
  11. I'm sure they didn't do it on purpose then. Sounds like a decent shop
  12. not good, nip over to new members section and introduce yourself first. might get a better response
  13. inn
  14. hard luggage for me too, when I went to spain etc, just unhook them at destination and walk in like a suitcase. they are safer like Cynic says so brew stops are less fraught . Say hello on http://www.carpe-tdm.net/ipb/index.php loads of info for you there too
  15. stephanie key thing is to relax on the bike, everything becomes smoother then
  16. and you slice, i'm managing to get out every day to exercise which is something. I also have PLex on my Roku which has all the latest films and programmes. take care of yourselves and each other
  17. drewpy replied to drewpy's topic in Yamabyss
    my xs could shift if I rode it right. but then could just bimble too. Took me to southwest 200. 80 mph all the way in shit weather. never missed a beat. I do look after my bike though and try to improve them in anyway I can
