drewpy
Everything posted by drewpy
  1. drewpy replied to drewpy's topic in Projects
    I was taking off the neg, will try the feed (+)
  2. drewpy replied to drewpy's topic in Projects
    I'm off tomorrow, so in the mean time
  3. sorry Tommy not this time
  4. drewpy replied to drewpy's topic in Projects
    its directly with the battery, new wires. 12.6 volts. how long do you have to hold them to charge? and do I collapse the feed or neg?
  5. drewpy replied to Dazlin's topic in Yamaha Workshop
    sounds like clutch slipping then. hope you didn't put car oil in carbs will be gunged up so won't help in a smooth tickover
  6. drewpy replied to drewpy's topic in Projects
    TCI def work, couldn't get the coils to spark manually, but couldn't with any of them (4 sets) even the originals which do work. There is no power to the pulse pickups, they generate their own power no immobilisers fitted, got an led to light on the pulse coils So what am I doing wrong if I can't get them to spark manually as 4 sets wont work and they are wired directly to the battery
  7. its because there is no fluid, the seals have a hard time pulling it through. most suck it through via the caliper and once you get a fair amount of fluid going, it should operate as it should. Took me 2 days on my twin caliper setup to do mine. do a search on the forum as its a common issue.
  8. drewpy replied to drewpy's topic in Projects
    well that didn't work wonder if 0.4 to 0.5 AC volts from trigger coil is correct?
  9. cheeky fecker! I had a piranha on the tracker but it went down on 1 pot. I did get one made which used the points as a trigger and was really reliable. I got it from Germany but he has stopped building them. I have got plans to build your own if your up for it? try Pamco Pete on mikeXS http://www.mikesxs.net/product/14-0999.html
  10. drewpy replied to Dazlin's topic in Yamaha Workshop
    hope your not puling in the clutch to kick the bike over, otherwise it wont connect to the crank.
  11. drewpy replied to Cynic's topic in General
    there was a site where that sold M/C seal kits by size. lost the link in moving computers though so you'll have to trawl google. It was an artisan web page not from a main stream site.
  12. drewpy replied to drewpy's topic in Projects
    I'll try anything at this juncture
  13. done a good job there considering what you were working with! now come over to my gaff and get this engine sparking
  14. to the YOC As slice says, post workshop problems in the workshop/classic bike section please!
  15. looking good, although toecutter would berate you as he rode a kwaker
  16. http://www.partsnmore.com/parts/yamaha/dt175/?filters[fitting]=custom
  17. africa,doing protheitcs or something
  18. no images
  19. drewpy replied to drewpy's topic in Projects
    coils are earthed to frame and separate wires to 12v and ignitor. Next I'll try a manual fire of coils
  20. youneed to buy for the engine,not the model so check for differences via parts book and you will find they share the same part #
  21. just got this from eBolt. good addition http://www.ebolt.co.uk/bmw-sat-nav-mount-25mm--1-ball---stainless-suit-ram-mount-new-soft-grip-design-6553-p.asp
  22. sounds like its starving of fuel either carbs need cleaning or the petcock is partially blocked
  23. drewpy replied to drewpy's topic in Projects
    nothing, nada, no spark! rewired it separately from the loom, have power pulses from pickup, 12v off separate battery (common earth to frame for coils), dyna coils, fuck all
  24. drewpy replied to drewpy's topic in Projects
    yep, it got wrote off and the cheeky feckers wanted £800 for me to buy it back, wouldn't even negotiate
  25. first thing I do is put new wheel bearings on a bike and then check age of tyres! good call
