drewpy
Everything posted by drewpy
  1. see Allen Millyard's youtube channel and say casings can't be welded. I've had a motor mount welded up and its no problem for 10 years its been on there. You need too make sure all oil is out but some castings can be porous and there may be an issue
  2. I think you need to get it on a dyno just to check fuelling and see the power curve. will save a lotto time in the long run Run it in first though as dyne's are brutal
  3. drewpy posted a topic in Random
    Two wives decided on a girlie night out. On the way home they needed a pee and nipped into a graveyard. Then they realised that they didn't have any wipes to finish up, so the first one used her knickers, and the second one found a wreath and used that. The next day one husband rang the other and said 'No more girlie nights out, mine came home with no knickers on'. The other said, 'Well if you think that's bad mine came home with a card in her crack that said 'From all of us at the fire station - we'll never forget you.''
  4. my mate has the tracer GT
  5. usually a captive nut, even if it did fall in, just use a magnetic aerial thing to fish it out
  6. I'd love to meet up again. going to be a strange year though I think.
  7. very simply, a diode is a bit like an electrical valve, it lets electricity flow one way and blocks it going the other way. stops damaging feedback to other electrical systems
  8. Just found Tommy's ride and slide photo 🤣
  9. i know it was, hence the emoticon it was shrek
  10. Dr and the medics
  11. it was me, I did leave a note but it didn't process.
  12. I think I adapted my throttle tube on the FZ to make it more quick action. I'll have a think on what I did or where I got the info from found it, i grooved the pvc to keep the cable from jumping off (it never did but I felt it needed it) https://www.kawiforums.com/threads/quick-turn-throttle-mod-with-pvc.122605/
  13. looking at this fiche, its a bearing https://www.fowlersparts.co.uk/parts/4012594/yp250-5sj2-2002-060-a/rear-arm-suspension should be able to buy from a bearing supplier if you can get the number off the bearing it self. heat up the alloy first and press out straight. oil seal will pop out using a small pry bar 93306-302YK
  14. Merry Christmas everybody. Family still Covid free (a few on front line police force too) Stay healthy 1f14a9be-1691-4cd8-9b03-ff3e87a1c5b2.MP4
  15. you take my breath away, a good group. what do you play?
  16. usually carbs and their ickle drillings try some easy start down the carbs to see if she fires up, then you have your culprit
  17. drewpy replied to mike1949's topic in Yamabyss
    Ruby Tuesday?
  18. drewpy replied to mike1949's topic in Yamabyss
    mike, you can't connect to a WhatsApp image. you would need to download it or take a screen print first
  19. bloody hell, all we need now is AndrewElvis to make an appearance
