Everything posted by choppernorgate
The Regular Birthday slot
THANX GUYS Had a great day, new mobile, coat, ps3 games Thanx again
Disc brake lock stuck!
No push the calliper with your hand, this will retracked the piston in the callipar, the fluid will be pushed back up the brake cable and in to the cup, so mind it dont over flow, it just needs a ml or two, that will release the pads from tuching the disc, leaving it free to turn the wheel with out them rubbing any grit that may on the disc. Good luck, its quit straight forward,
PASSED
CONGRATS, might wont to think about cost of insurance first, but Good luck
Take off the brake resovoir cap, push the brake calliper against the disc, not to let the fluid over flow, the put cap back on, spray disc with disc cleaner turn wheel whilst wiping it with a clean cloth, Good luck
R125 insurance - £1700....?
when i first started to ride, some moon ago, i got me a 11year old bike, heap of well yes, and i had my new bike insuranced as a second bike, worked out lot cheaper, not sure if you can still do it, i think you can, good luck
The happy couple
BIG Congrats to Goff and Mark, Best of luck,
HELP
-------------------------------------------------------------------------------- Really need your advice for a serious problem! I suspected for some time now that the missus has been cheating, The usual signs are there...The phone rings, if I answer the caller hangs up, Going out with the girls a lot...I try to stay awake to look out for her when she comes home but I usually fall asleep, Anyway last night about midnight I hid in the shed behind the "Blackbird". when she come home she got out of some blokes car and was buttoning up her blouse, next she took her panties out of her handbag and slipped them on, It was at that moment I noticed it!!!..........I had a crack in my fairing.....Should I try plastic welding or would it be cheaper to source a S/H one off E-Bay.......
Ace cafe
the guy sitting behind you is chris from the london bikers club, nice guy, did you chat to him? Resized to 94% (was 1024 x 768) - Click image to enlarge
anyone know about engines?
It can be done, But I dont think the teeth will hold on to it for long, I would try a smaler cog on the front and a biger one on the rear, Good Luck
Help! reg/rec info needed!
HI I use http://www.bitzforbikes.co.uk/products.php ive used these a 3 OR 4 times, had no probs with them, saft too. GOOD LUCK
Ace cafe
THE FIRST MONDAY OF EVERY MONTH LONDON BIKERS MEET, ITS A GOOD NIGHT
case con:
got this one to. A most extraordinary trial is going on in the High Court at the moment in which a man named Chrysler is accused of stealing more than 40,000 coat hangers from hotels round the world. He admits his guilt, but in his defence he claims that – well, perhaps it would be simpler just to bring you a brief extract from the trial. We join the case at the point where Chrysler has just taken the stand. Counsel: What is your name? Chrysler: Chrysler. Arnold Chrysler. Counsel: Is that your own name? Chrysler: Whose name do you think it is? Counsel: I am just asking if it is your name. Chrysler: And I have just told you it is. Why do you doubt it? Counsel: It is not unknown for people to give a false name in court. Chrysler: Which court? Counsel: This court. Chrysler: What is the name of this court? Counsel: This is No 5 Court. Chrysler: No, that is the number of this court. What is the name of this court? Counsel: It is quite immaterial what the name of this court is! Chrysler: Then perhaps it is immaterial if Chrysler is really my name. Counsel: No, not really, you see because... Judge: Mr Lovelace? Counsel: Yes, m'lud? Judge: I think Mr Chrysler is running rings round you already. I would try a new line of attack if I were you. Counsel: Thank you, m'lud. Chrysler: And thank you from ME, m'lud. It's nice to be appreciated. Judge: Shut up, witness. Chrysler: Willingly, m'lud. It is a pleasure to be told to shut up by you. For you, I would... Judge: Shut up, witness. Carry on, Mr Lovelace. Counsel: Now, Mr Chrysler – for let us assume that that is your name – you are accused of purloining in excess of 40,000 hotel coat hangers. Chrysler: I am. Counsel: Can you explain how this came about? Chrysler: Yes. I had 40,000 coats which I needed to hang up. Counsel: Is that true? Chrysler: No. Counsel: Then why did you say it? Chrysler: To attempt to throw you off balance. Counsel: Off balance? Chrysler: Certainly. As you know, all barristers seek to undermine the confidence of any hostile witness, or defendant. Therefore it must be equally open to the witness, or defendant, to try to shake the confidence of a hostile barrister. Counsel: On the contrary, you are not here to indulge in cut and thrust with me. You are only here to answer my questions. Chrysler: Was that a question? Counsel: No. Chrysler: Then I can't answer it. Judge: Come on, Mr Lovelace! I think you are still being given the run-around here. You can do better than that. At least, for the sake of the English bar, I hope you can. Counsel: Yes, m'lud. Now, Mr Chrysler, perhaps you will describe what reason you had to steal 40,000 coat hangers? Chrysler: Is that a question? Counsel: Yes. Chrysler: It doesn't sound like one. It sounds like a proposition which doesn't believe in itself. You know – "Perhaps I will describe the reason I had to steal 40,000 coat hangers... Perhaps I won't... Perhaps I'll sing a little song instead..." Judge: In fairness to Mr Lovelace, Mr Chrysler, I should remind you that barristers have an innate reluctance to frame a question as a question. Where you and I would say, "Where were you on Tuesday?", they are more likely to say, "Perhaps you could now inform the court of your precise whereabouts on the day after that Monday?". It isn't, strictly, a question, and it is not graceful English but you must pretend that it is a question and then answer it, otherwise we will be here for ever. Do you understand? Chrysler: Yes, m'lud. Judge: Carry on, Mr Lovelace. Counsel: Mr Chrysler, why did you steal 40,000 hotel coat hangers, knowing as you must have that hotel coat hangers are designed to be useless outside hotel wardrobes? Chrysler: Because I build and sell wardrobes which are specially designed to take nothing but hotel coat hangers. The trial started on Tuesday and continues
DRIVING LICENCE
Ok, I just read this on another site and thought it was a good point, Ok, I'm pretty sure this has been discussed on here before, but thought this would be as good a time as any to remind everybody out there to check your expiry date on your drivers licence photo card. I only say this because I've recently recieved the reminder and necessary forms to renew my photo, as it's well over ten years old! (13 to be exact) Even though I had a new one issued in January 2008 when I passed my direct access. Any way, check the photocard, and get ready to pay out £20 for the pleasure of updating your mugshot! Not only that, but it's not uncommon for people to forget about it or not realise, and then they're driving without a valid licence! and do take a photo copy of both sides, coz some peeps, have had to resit there test,
BIKERS ANGEL
Biker Angel please be my guide as I climb my Bike to ride. Let your halo guide the way and keep me safe from harm today. Let your wings provide the wind and air and send it coursing through my hair. Show to me a sunny place and let it shine upon my face. Keep the clouds and rain at bay and keep me dry through the day. Watch the friends who ride with me keep them safe and close to thee. Keep my wheels upon the ground so I'll return safe and sound. But should disaster be my fate, guide me through to Heaven's gate.
Would you give me your opinion ?
steel once you get fined, steel twice you go inside steel third time you get hands choped off, this one died, saved tax paying money,
how brainy r u
http://www.mikescomputerinfo.com/inteltest.htm i scored 6
- Wind chill chart
can you guys help
thanx i let him know,
can you guys help
Hi guys, I own nowdays a Yamaha TDM 850. It has a 2 to 2 aftermarket (think it is nexxus) exhaust sytem. I want to change from 2-2 to 2-1. I bought the necks of the exhaust that bring the 2 outlets into 1 just under the engine. I also got myself an aftermarket viper can. I need a garage/shop to create a link pipe and install the whole exhaust system. Had a look online, couldnt find anyone. Any suggestions? The place where I service my bike said they couldn't help unless I had the whole exhaust. Many thanks, THIS IS FOR A FELLOW BIKER, ITS NOT MY BIKE, THOUGHT WHO BETTER TO ASK
your tits needed
T-cut takes out scratchies on plastic to good luck
STOLEN, London SW9 - XT600E
sh..t sorry to hear this im u in essex work in nw10 will keep eye out tho never know might get lucky, hope you get it back soon ps ive put this out on londonbikers club most of them are over sw
- Movie Title Game
Movie Title Game
gone with the wind
Word Association Thread
burnt
Movie Title Game
everythings not as it seems
