Twincam
  1. Easy tiger... They just want more money, we dont want to pay them a penny. Its how it works (Problem is, if we don't pay, we get fines )
  2. Twincam replied to square box's topic in The Bar
    Hmm I see where your coming from, and I've plugged many tyres over the years... Just never superbike tyres.
  3. Twincam replied to mervin's topic in Yamabyss
    Should have done that! There was a lot more police officers patrolling the streets of London as crime rates rise on the night of halloween.
  4. Twincam replied to mervin's topic in Yamabyss
    ... did you just get that? IMO its sick and twisted... Probably someone playing a prank.
  5. Twincam replied to square box's topic in The Bar
    If done professionally, you can get the rear tyre plugged... (from the inside instead of out) Personally I would swap it but it depends what you want to do.
  6. +1 on the fuses... Make sure your switch gear is clean and "healthy" as some times there can be problem with the red cut-off switch.
  7. Twincam replied to fostersice's topic in General
    Have you taken her for a spin yet?
  8. Be careful with the wire wool - depends on which one you get as there is different levels of abrasiveness Ive got some 0000 wire wool, the finest sh*t you can get Works wonders, if its difficult to work on, use some wd40 on the wool (but make sure you clean it throughly after)
  9. Twincam replied to joeled's topic in The Bar
    I used to have 6V 21W bulbs in thr RXS - I had to buy a flasher unit but when I replaced it, the indicators seemed as if they needed to power up every time they flashed. I swapped them for 6V 8W bulbs, although they are not as bright, they flash at a constant rate and IMO are better.
  10. Twincam replied to Morgy's topic in The Bar
    Make sure if you forget, to then allow for the starter to cool down or u'll burn it out. I usually get half way down the road, then she would just die... Silly mistake but is a pain in the arse when you do it.
  11. How about Hamerite? I've used silver on the side engine cases and black on both the down pipe and head. They can withstand heat quite well, can be painted over rust and you can get various finishes (different pots have different finishes)
  12. Twincam replied to Morgy's topic in The Bar
    The reason for the taps originally was for the Gravity Fed fuel system... If you leave it open in some cases it can flood. Might as well turn it off if you know your not going to use it for a few hours... But, don't forget to turn it back on!
  13. oldgitonabike was right, my RXS does the same.
  14. Its not that I want to wheelie (Ive got the blade for that), its just I would like to have the power in order to wheelie if I ever needed to (not sure when but sounded right ) Might have to weld a 12 O'clock bar and some engine crash bars, add some renthals and see what I can get
