wild foamy
  1. yes it will work, but keep an eye on your wiring as the loom may not be designed to carry the higher current,
  2. wild foamy replied to mervin's post in a topic in Yamabyss
    thank f*ck i was born in the 90s... would have been an interesting swimming lesson
  3. can you not seal it with epoxy resin or cyanoacrylite? (superglue), ive had to do this on a mdoel aircraft fuel tank and it worked well
  4. wild foamy replied to Babybexx's post in a topic in The Bar
    whilst we're on the subject... where's Goff?
  5. wild foamy replied to black night's post in a topic in Yamaha Workshop
    a good set of lock pliers should suffice, if not try grinding a slot into the head and use a flathead screwdriver to remove it
  6. wild foamy replied to Mckay's post in a topic in The Bar
    Welcome to the asylum, thats a nice little bike you got there, doesnt look like there's a lot to do to it is there?
  7. wild foamy replied to hate_camel's post in a topic in The Bar
    i know the feeling, i dont like being in cars, i choose to ride if i can because i feel like i have direct control of the bike it could all chang ein winter, however, being able to get into my warm car with a heater... and a windscreen... and a huge soundsystem... and recaro seats... and a set of phat alloys... and a little set of fluffy dice hanging from the rear-view mirror... ford capri 1.6 laser
  8. wild foamy replied to Babybexx's post in a topic in The Bar
    i've warned you before about teasing me, BWJ
  9. wild foamy replied to barkwindjammer's post in a topic in The Bar
    i said no such thing!, perhaps he is just trying to get away from us... who could blame him, though...
  10. wild foamy replied to barkwindjammer's post in a topic in The Bar
    i think he may still be on his holiday
  11. wild foamy replied to Babybexx's post in a topic in The Bar
    Hello and welcome to the asylum
  12. wild foamy replied to vic-fzr600's post in a topic in Yamabyss
    my whole childhood lays in tatters... i hope you're happy
  13. wild foamy replied to barwell1992's post in a topic in Naked
    aren't you supposed to be restricted to 33bhp for 2 years? , im sure with the power commander and K&N air filter its going to be a little more than 33, if i remember correctly the stock MT-03 is 44bhp? still its a very nice bike, my instructor on my CBT had the MT-01 with heated grips
  14. wild foamy replied to langers_2004's post in a topic in The Bar
    from personal experiance, i can say that the performance "pod" air filters are more hastle than they are worth, i had one fitted to my DT50 and it caused it to run rich at mid-revs and bog down, and then run slightly lean at high RPMs
  15. wild foamy replied to langers_2004's post in a topic in The Bar
    Welcome to the asylum, thats a nice steed you got there
  16. wild foamy replied to checkley8's post in a topic in The Bar
    hi there idealy you will need to change the main jet to a larger size to compensate for the higher airflow through the engine because of the new exhaust, you may also want to change your rollers to a lighter set and stiffer clutch springs for faster acceleration take the bike out for a spin and full-throttle it, then cut the engine and coast to a stop,remove the spark plug and check the colour of it on the end (should be a dark brown/chocolate colour or black), if it is white and chalky this indicates a lean running engine which will soon destroy itself
  17. wild foamy replied to Connor James's post in a topic in The Bar
    ha, only in america! , id have thought you had an abundance of minks what with you being out in the middle of the desert
  18. wild foamy replied to steve.. Oh's post in a topic in Yamabyss
    by all means bolt it on, unlike the peds there is no centrifugal clutch or rollers to worry about. however, make sure to keep an eye on your mixture as the increased airflow through the engine will require extra fuel to work properly
  19. wild foamy replied to Connor James's post in a topic in The Bar
    Comma chain lube for me, give the chain a good wipe with WD40 and an old rag to remove the grit & shit and give it a good spray with the chain lube
  20. Oh, you so didnt...
  21. could be a clutch problem which (hopefully) wouldnt be the end of the world, however, if the chain amanged to lock the output shaft of the gearbox you could have shredded a gear or sheared a shaft. start with the clutch, take off the engine case and inspect it for any damage, if that checks out then split the cases and give the gearbox a good going over
  22. wild foamy replied to barkwindjammer's post in a topic in The Bar
    you think too much... you really do
  23. wild foamy replied to mick-h's post in a topic in Yamaha Workshop
    checked the bulb?, could have burnt out the tail light filament
  24. wild foamy replied to daneff's post in a topic in The Bar
    Score
