wild foamy
  1. Well it wasnt the royal mail, it was the military supply chain lol, was sad to see it go, was going to have it mounted on the wall
  2. Also, the plan for this bike is to do everything i can myself, with the XJ i had the wheels refurbed, forks redone, frame powdercoated, engine head welded, carbs rebuilt and will probably have to get an exhaust system made for it. but for the DT it will hopefully be used as a cheap alternative way to get around the RAF base and the local area without having to run the car on short trips, i will spray the panels myself, probably enamel paint the frame, re-coat the inside of the tank, the only thing i may have to get redone is the forks as the chrome has flaked off around by the yokes, but other than that its all my own work. im hoping to have this bike done for under £500, possible exception being the forks Drewps: that acoustic is staying where it is, its only a Nevada dreadnought anyway so nothing special, i bought an unbranded one off the jinglies in afghan on my first tour and took it everywhere i went, anyone who played it (or tried) had to sign it with permanent marker, it got signed by americans, afghans, estonians, pretty much a person of every nationality that was out there, sadly it got trampled on when i posted it back to my UK unit
  3. The nut should definately not be finger tight, i would suspect someone has had that flywheel off there before :s
  4. Check it out peeps, wether its tyre beads, prop wash or adjustable power bands, you can find it all here! Looky Looky
  5. wild foamy replied to mervin's topic in Yamabyss
    I saw him laying in the road the other day, lick his ball races...
  6. wild foamy replied to tgsm7's topic in The Bar
    i would advise against machine washing, all our military issue goretex stuff looses its waterproof properties when washed and im assuming that the spada gloves will use the same sort of technology i would suggest turning them inside out and using a mild detergent (fairy liquid) with warm water to gently scrub the inside and hang them up to dry naturally
  7. only problem is with wearing vinyl/latex gloves as unders is the sweat doesnt get removed, so you end up with sweaty hands also, when your car is refusing to start in the cold weather or needs that little extra kick to get going, de-icing windscreen spray doubles as an 'easystart' alternative when sprayed directly into the intake in small doses, a must have for any classic mini owner , alternatively de-oderant spray will suffice
  8. np martin, just wondered as that was my old DT and would love to have it back. as above, make sure you have a method of holding the flywheel whilst you tighten it up, the flywheel pullers arent expensive, check out Yambits on eBay, he usually has all the tools you'd need
  9. i dont see the problem with riding all year round aslong as you are switched on enough to adjust your riding to suit the road conditions and what you can expect to find in certain places or 'VPs' (vulnerable points). for example a road next to a field that is prone to flooding, more likely to ice over in the winter months. as for your test, i spent about £750 on mine because i had to retake my Mod 2 and had more lessons whilst waiting for the second test, and the wankers at the lights?, wait until they fuck up and bin their several grands-worth of crotch rocket then ride past flipping them the bird removed the second post
  10. welcome to the forum, and congrats on buying a DT50, i bought 2 quite recently after recalling fond memories of my old DT at 16, (do any of your DTs have the registration G237MYA btw?), the later models were CDI but the earlier ones were just points, it would be possible to take the old flywheel and points set off the engine and replace them with the new bits as to my knowledge the engine blocks were exactly the same, i do have a wiring diagram for the original DT that had points if your interested?, i made a whole new loom for one of my bikes
  11. wild foamy replied to dt502001's topic in The Bar
    Sir, ive tried seeing things from your point of you, but i cant get my head that far up my own arse. - Foamy,
  12. wild foamy replied to mervin's topic in Yamabyss
    Your presence will suffice, grouch
  13. Assuming it is a PREDATOR system it could be possible as they design most of their systems to enable use of a centrestand, to be 100% sure i would say give them a call, when i was looking at getting one built for my XJ650 Turbo i rang them up and they were extremely helpfull.
  14. As does laying warm fudge in your undercrackers
  15. wild foamy replied to Preload's topic in The Bar
    bollocks, if i wasnt away over the weekend i would nab some for the DT and XJ
  16. common problem, my XJ had the same problem and i found it had melted the plug that went into the reg, spares are available cheapest on eBay, just search XJ600 regulator and make sure it is for the pre-div years (84-91 i think)
  17. wild foamy replied to mervin's topic in Yamabyss
    Yeah, sick bastard tried doing it with a house brick, the dog BOLTED as soon as he saw what was going to happen XD
  18. you think im mad now, just wait until my debut at squires after a few pints...
  19. well yes but i just assumed it was because it was a small bird, you could probably say the same about a hamsters arse
  20. If i was driving the mini to work today i would have drowned! nice weather for ducks though, i suppose and on the subject of ducks, there has been a theory developed at work, it started off just to wind up the Navy boys that have infested our hangar, but basically, if a ship gets a hole in the bottom it sinks, right?, then why dont ducks sink? therefore they must have a watertight ass just a thought...
  21. the 2-stroke bike you have will have ports within the barrel to draw in the fuel/air mixture, wheras the four stroke big bore kit will not have as the fuel/air is drawn in by overhead valves and will not have the ports in the liner you require thats just how it is im afraid dude, save your money for the DR400, they are good bikes and i nearly bought one until i got my XJ600
  22. thats the last message i sent after being called up one evening and being shouted at by the phone, after 3 messages in one day asking where the item was despite the fact i told him i had sent it standard parcels the day before and it would take roughly 3-4 days
  23. wild foamy replied to myrulez's topic in The Bar
    salaam alaykum, please post an intro, it helps us know a bit more about you, your bikes, where your from e.t.c, more a friendly approach . Google is a very usefull tool for manuals, i found one for my DT50 on there
