Cynic
Everything posted by Cynic
  1. Don't know about anybody else but I have clocked up a few miles this winter. I have done my time being a full time motorcyclist and much as people may say otherwise, for me, fuck that!. My car is cheaper, quicker (yes if you include putting all your gear on, unlocking the garage, then the bike etc) and warm and dry. But I have been out using the bike. Bloody good it feels too. Its cold granted but the roads on the whole of late have been salt free and relatively clear of the usual winter slime. Even some sunshine. I know it cant last and Feb will blast us, or March for a late frosting who knows. But for now, yay.
  2. Cynic replied to Cynic's topic in General
    That's the thing drewps, this already HAS the expensive bits. Need to change the crank seals and that defacto means the bearings too. Would you believe the mag side seal had literally come out of its seat.when I pulled the rotor the seal fell onto the bench. I can only assume it was blown out by high compression of the sports piston kit, (one ring high comp). It already has the piston and head, the pipe etc. A bloody good clean and removing all the teenage balls ups. Like airline for coolant pipes, ???. Amazing how few bodywork fixings you actually need. Couple of hours and it was a big pile of bits, all came apart easy too, surprisingly no seized bolts etc. Granted one or two had me reaching for the plussgas but even the engine mounting bolt (as notorious as the dt one) slid straight out. Cannot argue can I. Whats good for the goose etc. Daughter number 2 did say she got serious cool points being dropped off on the max the other day, that would be the shy retiring type with matt black lid with electric blue pinstriping and ghost skulls..
  3. Cynic replied to Cynic's topic in General
    Not sure she needs the theory, doesent the car theory test count.
  4. Cynic replied to Cynic's topic in General
    Maybe, no1 daughter is in Shefield doing psychology. Maybe in the summer break, we might pay for her to do one of those week courses for her birthday. She only wants to ride my cb175 so the licence restrictions from her age don't matter.
  5. Cynic posted a topic in General
    I thought I had bought a scoot for the daughter, needing nothing more than some spit and polish and maybe a mild de restrict went to collect. Nope sold to somebody else, sob story of forgot/my partner sold it….. Anyway, calmed down after that and now have an Aprilia sr50(ish), does have an 'oversize' piston. Bike is ok in the main. The engine.....hmmm spanners are getting dirty, really dirty. I should not be surprised at the state of learner bikes but I don't recall any of 'us' in my day doing some of the stupid shit you see on these scooters. Drive belt on backwards, the arrows are clear enough to see. No starter gear, just gone, removed, these things only start on the kick as a get you home (cos its hassle). Air line used as fuel pipe, coolant pipe and vac line, It was a dead duck (cheap) and has a bad crank seal so the motor has come apart, still trying to split the cases. Bit of a pain, think heat will help, but it has got some good proper sports parts in there and will be a rocketship with the daughter on it. Things like the coolant came out clean as a whistle and aside from being dirty all the fluids are good (little gearbox at the rear) and nothing seized up. Only stumble is the cases hanging. Stupid sidebar to splitting the cases, the cost of the proper tool to split the cases cost very little more than buying replacement cases from ebay. Actually fun to work on and when you get into them there is some very clever thinking to the design. Looks like were keeping it too as the wife fancies using it for work once daughter number 2 has passed through it.
  6. Any coolant suitable for aluminium engines will do if your really stuck. Use as per the bottle. You need to figure out where the coolant has gone too.
  7. Bet your arse it's not a run. Misspent youth making sure of that.
  8. Yep, the chilly willy run from Billing garden centre. Weather looking really good so will be loads there. Raising money for the air ambulance. 50 or so miles round Northants and into Bedfordshire a little. Bloody freezing last year.
  9. Cynic replied to slice's topic in General
    It still doesent compute in my mind slice but the last time I saw the inside of a class room as a student Maggie had the big chair at no10. Paul and Merv have far more current (geddit) technical knowledge and I know when to shut up.
  10. Cynic replied to slice's topic in General
    So why have a fuse block with 5a 10 a and 20 a fuses, by that line with 30a of load why do the fuses not pop. The current in the wiring of my house should be the same as the secondary of the step down transformer that feeds my estate then? I know im 20 years, er more like 30 out of date on the math, I just cant see it.
  11. Cynic replied to slice's topic in General
    Yesssss forum discussion. Not been one of these for ages. The way i see it current is the measure of energy, the energy after the above example has to be less due to the energy expended as heat. One side of the heated grips will have less energy than the other, incoming side from the action of heating needing energy. My theoretical grips have 96watts, that's work done, power, current drawn and radiated as heat. If the output from the grips was the same as the incoming that's grips heated without using any energy. How does volt drop figure due to load and resistance. If you powered a light bulb through 10 miles of lighting flex there would not be enough energy left to light the bulb. Newton versus Kirchhoff. Kirchhoff is talking about a very specific point in a circuit. Not the whole circuit including load and losses. Purely on experience switching post load needs less capacity and results in smaller switches being needed.
  12. Cynic replied to slice's topic in General
    Electrical principles mate, its bad on AC systems, well blody lethal really. On DC automotive systems it reduces the load on the switch and reduces voltage loss to the device your switching as well as reducing arcing within the switch. Switch a 10A dc load (heated gips say) on the live side your switching a 10A resistive load. Switch it neutral side and maybe 8 A have been burned up doing the heating so you only need a switch capable of 2A load to switch 10A, its not that literal but that's the logic to it.
  13. Cynic replied to slice's topic in General
    Use the horn wiring, just put a relay where the horn still is or where you can conveniently access the connections from the loom somewhere behind the fairing. Fit the relay here, using said relay you can have either new or old depending on switching, a switch you can put wherever aesthetics or need suggest. The default position (non energised) leaves you bike in stock config. That way if the new stuff fails you always have the horn, (yep deliberate). From that point just wire up your super horns with whatever magic gets the extra voltage? Using the brake light circuit to feed high power horns is not a good idea, if your hitting the horn. You are most likely braking, that means full load on that circuit plus whatever the horns pull. You may lose the horn when you need it most...… (?) …. Er. Fresh line from the battery, or pick up on a non essential. Heated grips? Phone charger?. Lose those in a critical moment it makes no odds.
  14. Same here run em up, going out on the max tomorrow if the weather stays as is.
  15. Cynic replied to huxley's topic in The Bar
    I would be surprised if a 125lc is still stock at over 30 years old, hell chasing 40 years old. They were never actually restricted as such and should have solid poke stock, (around 14-15hp in good nick) borderline legal for L plates these days. If your just after fast why not go for a later DT, the early powervalve bikes are best if you can find one.
  16. Following Drewp's line.. Feliz navidad y prospero ano nuevo.
  17. That's the one.
  18. Same. Did 5 years on 2 wheels full time because I could either afford a car or a bike but wanted a bike. Teaches you a lot. Mainly that riding all year is shite.
  19. Im in, cool photo for the header.
  20. Then why not start one.?
  21. Yes yoc is on FB. We need to use it. Just search for yamaha owners club
  22. Totally its Facebook, nobody wants to wait anymore. TDR forum has gone the same, vmax forum too. Its all facebook. We need to try and start on facebook. The vmax and TDR face book forums are running well.
  23. Crikey, expecting a reply from a one post wonder from a decade ago.... First thing is to start your own post, second, is your engine dead or just needs work. 125 engines don't get a lot of love and finding a good bolt in replacement is chancy.
  24. Are you sure there are 2 indicator relays. Doesent seem like something Yamaha would do.
