ringadingding
Everything posted by ringadingding
  1. yea might see if yamaha can play with it to get a little more from it
  2. 12bhp my yzfr125 is pumping out 15bhp from new lol
  3. ringadingding replied to Geordie83's topic in Naked
    better than not having a bike at all
  4. theres a exhaust on ebay
  5. i sourced new parts
  6. well i got bored with the black so changed it like i said and heres the results folks (what you think)????? comments please
  7. well i aint lying i have acheived 85mph@10,500 rpm bouncing off the limiter so dont care what you say about it i know its true, just because you cant do it aint my problem.
  8. on the side where oil filter is located you have to remove the fairings, once this is done you wil see a pipe coming from the exhaust it conects to a little black box and you have to remove the 2 pipes running from it, then undo the 2 screws holding it together, and you will see a kind of diafram inside, i found a metal plate in there and was restricting the ammount of air going through it, so i adjusted the metal plateso the diafram opened fully to let more air into the airtake system. once all back together i tested it out and the results were not massive but very positive on respose and made it ride quicker than it was, and the top spped i had with oncoming wind was 85mph @10,000. before doing this i was doing 83mph @10,500 rpm so allthough not massive but more responsive and a good find for everybody. also removed the exhaust and there was not restricton on this apart from the cars, which when i get full system will make it even better. good luck guys cos this is so easy to do and will liven up your bike, try it and see. let me know how things go
  9. no if you look at what i have done to the bike it will helpp with the speed thing
  10. well i dissagree with you i'm 12 and a half stone and mine pulls all the way to 85 no probs
  11. yea i think ithas the same idea as the r1 frame and r6 frame
  12. yea it is a shame its a 4 stroke but hey gotta start somewhere i should have done the bike thing years ago. i have sourced new plastics and changing to top half of bike yellow and bottom half of bike black will look the nuts when finished
  13. hello guys i am getting bored of the black and was thinking of changing the tank, front fender and rear plastics for the yellow what you think? would it cost much to do?
  14. i may be a bit dumb but can i get a paddock stand for my yzf r125 as in need to work on the wheels mostly the front but want to paint the wheels and want to do the front first help please
  15. i cant wait
  16. yea had them pulled out yesterday and had a new cast put on as the bone is notquite healed yet
  17. my left wrist so i cant even pull the clutch lever in
  18. umm not yet people as i fell off a ladder and broke my wrist in 3 places so not even been able to ride mine.
  19. well if you dont want to hear about it dont read and coment about it that simple
  20. well glad to hear at last i knew it would make a little difference but not great lol when i found out more i'll post up.
  21. oakie dokie bud
  22. you have to remove all the fairings on throttle side of bike, then you'll see the pipe from the exhaust. you have to remove the hose off the exhaust but on held on by little clip so really easy there, then get a touch you should be able to see the metal flap inside then get screwdriver and move the metal as far back as you want. dead easy mate
  23. has made a real good difference so when i get an exhaust it will feel better
  24. what is your bloody problem
  25. on the side where oil filter is located you have to remove the fairings, once this is done you wil see a pipe coming from the exhaust it conects to a little black box and you have to remove the 2 pipes running from it, then undo the 2 screws holding it together, and you will see a kind of diafram inside, i found a metal plate in there and was restricting the ammount of air going through it, so i adjusted the metal plateso the diafram opened fully to let more air into the airtake system. once all back together i tested it out and the results were not massive but very positive on respose and made it ride quicker than it was, and the top spped i had with oncoming wind was 85mph @10,000. before doing this i was doing 83mph @10,500 rpm so allthough not massive but more responsive and a good find for everybody. also removed the exhaust and there was not restricton on this apart from the cars, which when i get full system will make it even better. good luck guys cos this is so easy to do and will liven up your bike, try it and see. let me know how things go
