Everything posted by mervin
- Word Association Thread
When to change chain and sprockets?
i can only say the same as speedshop, been there done that myself luckily i did not have to replace the engine, some araladite and silver paint repaired it as it was only a non stressed cover
goodbye dear friend
My old black and decker i have had for 16 years is getting a bit sick now, it only gets used for wire brushing now, but it has outlasted a Draper one bought too replace it by the firm i work for, the spindle broke on that, I bought a non such 800w replacement from Maplins recently for about £15 in a sale and i have a big bugger bought for £18 a few years ago in a french hypermarket, that came with a spare set of brushes Merv
81 xs400 shift shaft replacement
i will bow to Drewps superior knowledge here as have never worked ona XS Merv
Bugger. :(
Nick Chambers (RDBITZ)will rebuild the calipers rsonably if you take am off and send em too him Merv
Power Ranger, Good or Bad?
He is only young and in need of education,does he think he is turpentine Rosso or summat, as for not having heard of the forum he can be forgiven once he is out of nappies and his mum and Dad let him use a computer he may find us
RD club rally 9th too 11th july
Sign up on the aircooled website for pics aircooled link this is us at weston super mud a couple of years ago thats me with the black jacket at the back of the red bike talking too Ish and Hazey , search aircooled rd and there are loads of videos on you tube
doubtful Paul i gotta work Merv
Ever owned and RD wanted to own one? wanna see more RD,s than you can shake a stick at at the MFN Shipley gate notts will put up the poster when photphuckit lets me up,load it
1974 dt175 clutch?
dont worry about disconnecting the oil pump just leave it connected and tie it out of your way, saves having to bleed/reset it afterward Britain and America divided by a common language
ypvs ignition
try andy yamahardbreaker ask him if he has one through ebay http://cgi.ebay.co.uk/YAMAHA-RD-250-350-lc-coil-/330429539731?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item4cef22a593
Headlight Lense MELTED....
in which case i would complain loudly to yamaha
Gas Cap Gasket for 1976 XS 500
yes that will have a gasketv merv
Have you fitted a bigger headlamp bulb??? if sothis could explain why it has melted cos the bigger the bulb the more heat it puts out, I would go too a dealer and if they are good they will tell you if others have had a problem, if so fire a few mails off to yamaha themselves and see what hey say merv
- 1974 dt175 clutch?
quick question, concourse?
uttoxeter this weekend will be all vintage jap stuff
xs650 ignition coils on xs400, possible?
Arian wanna save $5 per coil PARTSNMORE LINK get em from partsnmore RD400 ones are the same
doesn.t time fly
10 years ago today yer maun died Race/Rest In Peace Joey
2 wheels the bottom pic is the left side of the shift shaft, they are the same as the Rd and i have done em in the past without removing the clutch no problem merv
Online parts ordering - any recommendations?
Wemoto,s batteries do not come with Acid unless it is a gel battery i think, so any battery from wemoto you need to add acid and most need 2X 500 mil packs at £2 each + extra postage, i know i got a battery for me Z650 from em the other day, by the time i paid for it all i had saved about £3 on an exide battery from the local specialist
Turn signal cancelators
get a new one or secondhand off ebay??
Mikes XS ones are $7 did you get a whole cap for$22 ??
1974 dt175 clutch?
i always stick a new set set of springs in any clutch i take out it is easier to do it at the time than have to tear it down again , use a bike specific oil, modern car oils can have anti friction additives that will make the clutch slip
hi there :) YZF-R125 help?
Get yourself a Rottweiler and inject it with the aids virus, then put a big label on it saying it has aids and keep it tied to the bike at all times, (No rottweilers were harmed in the making of this post)
1974 dt175 clutch?
you will need at least the friction plates and the springs possibly the metal plates as well and also a gasket for the cover, remove clutch cover, take plates out look at the outer basket and if it has ridges on the teeth file them off if they are not too seriously deep, then replace things in revers order, I:E one friction plate one metal plate, take note of how many friction plates you take out because some packs of plates cover several diferent models of bike and may have an extra plate in them for a different model merv
