mervin
Everything posted by mervin
  1. the caps simply screw into the wire, put the rubber sleeve on the wire first then slide it over the cap when fitted, with the coils unscrew the knurled plastic nut at the front of the coil, inside that you will see a rubber grommet remove the grommet put the nut over the wire thread facing the coil, then place grommet over wire, inside coil you will see a metal pin push wire into coil over pin, then slide grommet and nut up to the threaded part of the coil and screw up, the nut and grommet will clamp the wire in merv
  2. mervin replied to tonyl66's topic in Classics
    RK leighton springs to mind merv
  3. A bike made from donated parts with it's very own heart transplant. Papworth gave LC club member Foxie a heart transplant in 2006, so we thought we would give something back. The bike is to be raffled off at this years CMM show in Stafford, 19th October. All proceeds to go to Papworth Hospital. Tickets priced at £1 each and are available by sending a cheque and SAE to: The LC Club PO Box 7226 Wellingborough Northants NN8 9BZ
  4. I presume you mean the cap like this in which case if you have one you can open look underneath it ands see the position of the catch, you can then take a bent screwdriver and push it under the locked one merv
  5. you can undo the cap with a bent screwdriver just push it under the lock end, in england yuo can still get keys from a yamaha dealer just from the number or a decent key specialist merv
  6. mervin posted a topic in Classics
    Another RD 250 aircooled will be complete tomorrow pics here RD250 resto
  7. surely that is the wrong way round you ned to heat bearing and cool head as metal expands with heat merv
  8. mervin replied to Goff's topic in Yamabyss
    maybe one of the dealers here would help if you explained the situation and asked nicely royal enfield dealers merv
  9. look around the bottom of the race /stem you can see the join Take a small cold chisel (not a woodwork one) and tap it into the joint it should gradually part from the fork stem once it starts too move you can then lever it up, be careful not too damage the surface of the stem if you do clean it up before you try to fit the new bearing, and do not forget to put the seal in Merv
  10. ah yes the tiredkraut merv
  11. They are both suppliers for MIKESXS in the states i believe the parts lists are the same, i tried to order parts from the Netherlands did not even get a reply so the german guy will be getting my business from now on Merv
  12. Rudiger Paustian has a lot of stuff on his site and if you click the union jack at th top it comes up in english put your stuff in to the shopping cart and forward your order with your email addy and he will send back a total price and a paypal advice of what to pay with postage. his P&P charges are pretty good from germany not rip off like some foreign companies anyhow heres the site, Oh i was told Tony Hall of Halco topped himself, shame nice guy i spoke to him a couple of times getting brake caliper seals for my RD,s site xs650shop.de
  13. mervin replied to dd coop's topic in Classics
    the crank can be rebuilt the big end ball bearings will be replaced with the rest of the bearings and pins that they run in PJ engineering will do this for you they have a collection and return service, pj engineering they did my aircooled 400 crank a couple of years ago i think it cost £160 at the time too rebuild you get new rods bearings and lab seal all pressed together and trued up, Norbo may have some exchange units cheaper but rebuilt using the good parts from the crank not all new parts rdlc crazy merv
  14. well i see his son michael won the race, that must have taken guts merv
  15. mervin replied to moxy's topic in Yamabyss
    woman came home to find her husband tossing himself off in the kitchen, she rushes over and gives him a blowjob, he says well thats a turn up for the books no sex for six months now this, she said i washed the floor this morning it easier to rinse my mouth out and clean my teeth than wash the bloody floor again
  16. mervin replied to -XX-'s topic in Yamaha Gallery
    hi XX nice bike there where abouts are ya in holland will be there tomorrow merv
  17. mervin replied to Ondra's topic in The Bar
    Unfortunately newtronic went out of business last year, it has been taken over but they do not seem to be making kits at the moment, there is a chance a kit maybe lying around at a dealer or in the store at newtronics. website newtronics
  18. repair manual club
  19. Drewps Dont know bog all about modern XS,s so i stand corrected anfd thanks for doing that my specialist subject RD 250/350/400 aircooled before 1981 A good way of translating parts is go to german ebay enter the name of the part you are tryingto translate in the search box and hey presto you should have a picture merv ebay de Bremmszange = caliper? yes Hohlschraube = brake line? No quite literally hole bolt, but banjo bolt too us, to take 2 lines you will need another line of course Handbremmszylinder = master cylinder? yes
  20. Front twin discs, XS500/ 650 bits should do it, unless you can find a front end from newer bike that goes straight into your triple trees, as for rear shock again take a look around measure the shock and see if a later bike one fits I:e xj600 possibly merv
  21. mervin posted a topic in Classics
    i have managed to source a supply of stainless footrest mount pins fit most old yams XS/RD/ FS1E etc with a 6mmx 35mm pin complete with stainless washer and stainless cotter pin £6 a set, paypal available ask for postage costs outside uk merv
  22. mervin replied to drewpy's topic in Classics
    contact him through CMM he is Chris Pearson there must be an email addy on the CMM website merv
  23. mervin replied to drewpy's topic in Classics
    Pm yamguru he was looking for bike retsos the other day for CMM Merv
  24. Cheers mate I know Alex will appreciate that Merv
  25. here's an online petition set up by a good guy and OYB bike training owner Alex Pinch, doing the rounds about delaying the launch of the MTC (New Super Test for Bikers) until all centres (across the country) are open. The DSA says they’ll all be open within 12 months, so why can’t they delay until April 09? This will affect the industry at a time when the country is facing a financial crisis. This affects all of us, with some new riders being expected to ride a 3 hour round trip, just to get a licence and that’s not safe. Please pass this on, it deserves our support. Click here and sign up - http://petitions.pm.gov.uk/delaytheMPTC/
