sarah
Everything posted by sarah
  1. sarah replied to sarah's topic in The Bar
    That would be great many thanks, Is it possible to email diagram to me Sarah
  2. sarah replied to sarah's topic in The Bar
    Hi The problem is that everything is wired up and works, but the indicator warning light doesn't flash when indicators are on someone has connected them to the neutral warning light. Rather than pull the unit apart to find out which wires run from the connecting block to the instrament panel I was hoping to find a later diagram as the earlier ones don't seem to have the indicator waning light (probably why whoever did it connected it wrongly). All wires going to lamp units and relay are either choc brown or dark green but from the connecting block on there are none this colour!! Does this explaination make sense? Regards Sarah
  3. sarah replied to sarah's topic in The Bar
    Should have read instructions better on writing replies etc. Changed this message as I initially posted a reply here. oops.
  4. sarah replied to sarah's topic in The Bar
  5. sarah replied to sarah's topic in The Bar
    Hi Many Thanks for the link, unfortunately the Fs1e was one they didn't have. Sarah
  6. sarah posted a topic in The Bar
    Hi I've just joined and am wondering if anyone has a wiring diagram for the later Fs1e. Mine is F reg 1988. I have an earlier Haynes manual and it doesn't have the wiring codes for the indicator warning light etc. Please can anyone help
  7. sarah posted a topic in The Bar
  8. sarah posted a topic in The Bar
  9. sarah replied to sarah's topic in Classics
    Hi Thanks for the reply, I have the indicators working that was easy to fix, but I suppose I'm trying to take a shortcut hoping that someone has a diagram as I don't really want to pull the unit apart to sort out whhich wires are connected to the warning light. At the moment whoever wired it previously has wired the neutral light to show when you are in neutral AND when the indicators are flashing. So I've come to the conclusion that maybe they were using an older manual Iknow the manual was reprinted several times over the lifespan of the Fs1e. Many thanks for your help. I will as you suggest put a post on the home page. I hope your restoration goes well... The one I have is fairly tidy but I think that it should be blue not red as it is at the moment and I've yet to find a source for the Decals(either that or a bit of artistic flair) Regards Sarah
  10. sarah posted a topic in Classics
    Hi I've just joined and am wondering if anyone has a wiring diagram for the later Fs1e. Mine is F reg 1988. I have an earlier Haynes manual and it doesn't have the wiring codes for the indicator warning light etc. Please can anyone help.
