Posted January 24, 200817 yr I have an 82 XS400RJ, and need a new seat. I was wondering what other models will bolt up to the SECA 400. Any help is greatly appreciated.
January 25, 200817 yr Had a quick look in google images and the aircooled RD250 from around 1977 looks like it would be fitable, it even has the same trim around the seat base and tail light.
January 25, 200817 yr Moderator Had a quick look in google images and the aircooled RD250 from around 1977 looks like it would be fitable, it even has the same trim around the seat base and tail light. would have thought that a 250/350 lc would be closer than a aircooled as they were made around 82 Merv
January 25, 200817 yr nah looks totally different, if you look at the xs it looks pretty well identical to the rd except for the engine.
January 26, 200817 yr Moderator nah looks totally different, if you look at the xs it looks pretty well identical to the rd except for the engine. Yes the ordinary XS seat from the the seventies early XS maybe similar, i can list you a few differences but that is irelevant, the XS seca is a different animal
January 26, 200817 yr yeah your right its totally different i had a picture of the early one, the pre divvi xj600 may also be worth a look.
January 26, 200817 yr Moderator I have an 82 XS400RJ, and need a new seat. I was wondering what other models will bolt up to the SECA 400. Any help is greatly appreciated. try ebay germany. they liked the euro styling of this model and there are quite a few there. I def saw a (white) Guilari seat for that model on ebay not long ago here you are ebay #'s 280111501642 260206738584 140187893259
January 28, 200817 yr Author try ebay germany. they liked the euro styling of this model and there are quite a few there. I def saw a (white) Guilari seat for that model on ebay not long ago here you are ebay #'s 280111501642 260206738584 140187893259 Thanks to everyone for the replies. This forum has been most helpful.
March 6, 200817 yr check out www.yamaha-motor.com/sport/parts/home.aspx for part numbers and compare.
March 7, 200817 yr Moderator check out www.yamaha-motor.com/sport/parts/home.aspx for part numbers and compare. one on UK ebay right now
October 20, 200816 yr Moderator or even a customized seat would work. wonder if that ones gone from ebay yet
