I recently bought a 1100 Dragstar (secondhand) and when I opened the air filter cover quite a bit of oil came out.
I have not had any other issue ....spark plugs burning correctly... no other leaks found........no cracks etc in case.
Somebody said this could be a head gasket problem but can anybody confirm/offer advice please?
  • 5 months later...
Not to sure about DragStar's but I know HD's have crankcase breathers that run back to the air filter. Could this perhaps be the solution???
-Ryan.
The engine has a sealed breathing system and will deposit the odd bit of oil in the intake area. There should not be much but if there is, then there is a problem with blocked breathers or within the engine itself. If it wasn't a Dragstar I would have said that someone had wheelid it too much.
Clean the intake and fit new filters and change the oil. Check it in 500 miles.
  • 4 months later...
This is normal, you get some oil spray from the breather pipe from the crank!
Stu
