Posted March 3, 200717 yr i got some pics of my xt125 now that i have made some meager mod's like nos etc.. XT125 Pic 1 XT125 Pic 2 XT125 Pic 3 for me info and more pic add me on msn [email protected]
March 12, 200717 yr My Son has one of these bikes and he struggles to do more than 63mph, (when the speedo is working that is ) there has to be a way. My thoughts: Has anyone tried blocking off the small take off pipe from the exhaust that goes to the emmissions stuff? The outlet on the std exhaust seems very small diameter, does a replacement exhaust help much? Can anyone confirm this restrictor in the front of the exhaust?
March 14, 200717 yr Author mate if i am right what u are talking about that is like a EGR Valve just like a car it will recirculat the exhaust gases tho the engine agen saving more fuel if u remove this it will not do any to the bike ( i think ) but just use much more fuel than normal.
December 3, 200717 yr I've just bought the exact same bike as you Smithy, is the Gianelli system worth buying?
December 6, 200717 yr Nice bike mate! iv just brougha 2006 xt125x! does anyone know if it has a fuel gage? Tony
December 6, 200717 yr Nice bike mate! iv just brougha 2006 xt125x! does anyone know if it has a fuel gage? Tony Neiter of the XT's have fuel gauges (2005-2007 models) not sure about the 2008 though. They just have a little orange light next to the speedo that blinks whenever the tank gets to 2 litres, or if you ride above 60mph for more than 30 seconds, haha. I found the best way to tell how much fuel you have left is to reset your milometer when you fill up and count the miles before you run out.
March 23, 201014 yr Neiter of the XT's have fuel gauges (2005-2007 models) not sure about the 2008 though. They just have a little orange light next to the speedo that blinks whenever the tank gets to 2 litres, or if you ride above 60mph for more than 30 seconds, haha. I found the best way to tell how much fuel you have left is to reset your milometer when you fill up and count the miles before you run out. duuddeee!!! mine does!! its on the trip switch... however my 57reg doesnt have a reserve tap
March 27, 201311 yr Hello I have a Yamaha XT 125R And i can get 85 out of it flat out Utterly Fazed Is right in saying you need to bore out the outlet pipe like i did I will Put a list of mods i did to my bike to get it to achieve 85 mph Racing Carb 1.20mm Main Yet 4mm Bore outlet pipe Removed exhaust Baffles Put the Front and Rear suspension on the lowest setting I did just them without getting big bore Kits and sports cranks I spent £150 on the mods and got an extra 15-20 mph from it so its up to you how far you go with it Hope this helps
March 27, 201311 yr Hello I have a Yamaha XT 125R And i can get 85 out of it flat out Utterly Fazed Is right in saying you need to bore out the outlet pipe like i did I will Put a list of mods i did to my bike to get it to achieve 85 mph Racing Carb 1.20mm Main Yet 4mm Bore outlet pipe Removed exhaust Baffles Put the Front and Rear suspension on the lowest setting I did just them without getting big bore Kits and sports cranks I spent £150 on the mods and got an extra 15-20 mph from it so its up to you how far you go with it Hope this helps So boring out the exhaust will achieve higher speed?
March 27, 201311 yr Moderator No grouch it wont. Have you EVER in all the time you have had that bike trawling the internet to make go. Found an exhaust that can give that kind of boost. The dt struggle to pass a real world 75. Que the many million mph dts. He is blowing smoke up your pipe.
March 27, 201311 yr No grouch it wont. Have you EVER in all the time you have had that bike trawling the internet to make go. Found an exhaust that can give that kind of boost. The dt struggle to pass a real world 75. Que the many million mph dts. He is blowing smoke up your pipe. No and tbh I thought this thread looked dodgy with all the 1 post wonders contributing to it. It looks like the same person with multiple accounts.
March 13, 20159 yr No grouch it wont. Have you EVER in all the time you have had that bike trawling the internet to make go. Found an exhaust that can give that kind of boost. The dt struggle to pass a real world 75. Que the many million mph dts. He is blowing smoke up your pipe.
March 13, 20159 yr No its true that they can I've had 89 out of mine and that was GPS my speedo says 93. And it's stock apart from the handle bars
March 13, 20159 yr duuddeee!!! mine does!! its on the trip switch... however my 57reg doesnt have a reserve tap http://www.yamahaclub.com/forums/public/style_emoticons/#EMO_DIR#/sad.gif
March 13, 20159 yr My Son has one of these bikes and he struggles to do more than 63mph, (when the speedo is working that is http://www.yamahaclub.com/forums/public/style_emoticons/#EMO_DIR#/rolleyes.gif ) there has to be a way. My thoughts: Has anyone tried blocking off the small take off pipe from the exhaust that goes to the emmissions stuff? The outlet on the std exhaust seems very small diameter, does a replacement exhaust help much? Can anyone confirm this restrictor in the front of the exhaust?
