rd250 c 1976
hello all.....
does any one have or know of someone that has an original seat trim including pins and clips (only fitted to rd250c and 400c) 1976 ish ? ? :D:D:D
Try asking on here...
Here
...where someone will point you in the right direction.
Andy
Here
Andy
Andy... thanks for the reply and I have already posted a wanted for on that forum
hello all.....
I made my own using B&Q alloy channel. Bashed over and dremeled open the slit so could slide in ground down stainless flange button socket screws.
They look the business and cost £4 each side and the alloy doesn't rot and its easy to shape the ends to the correct profile!!
thanx for the info.... the problem is i dont know what an original one looks like so i have nothing to copy from(no dimentions) ? are you a member of the a.c.rd forum ?
No! as i have a 4 stroke xs400. the strips are similar to the xs though. I have added a few pics of what i did, and i could scan the ends for you if you like an PM you?
have you tried PGM yamaha?
this is the back of the strip although I have flattened them a bit more later
these are a comparison with an original
got the screws from here. Just ground down the head flat to the washer and use as template to judge the gap of the strip
http://www.a2a4.co.uk/acatalog/FLANGE_BUTT...SCREWS_A_2.html
quote name='drewpy' date='Jan 1 2007, 08:20 PM' post='38141']
thanks for the information thats more than helpful was the piece of ally a strip before you started shaping it ?
the c model had a thinner chrome trim that went right around the back of the seat and no tail plastic
Drewpy that looks like a good job mate, will have to remember that next time i want some trims,
here itRD250.jpg is
  • 1 year later...
lol. this picture is really the original of the bike. Take a look a the cars in the back.
