December 30, 200619 yr hello all..... does any one have or know of someone that has an original seat trim including pins and clips (only fitted to rd250c and 400c) 1976 ish ? ?
December 30, 200619 yr Try asking on here... Here ...where someone will point you in the right direction. Andy
December 30, 200619 yr Author Try asking on here... Here ...where someone will point you in the right direction. Andy Andy... thanks for the reply and I have already posted a wanted for on that forum
January 1, 200719 yr Moderator hello all..... does any one have or know of someone that has an original seat trim including pins and clips (only fitted to rd250c and 400c) 1976 ish ? ? I made my own using B&Q alloy channel. Bashed over and dremeled open the slit so could slide in ground down stainless flange button socket screws. They look the business and cost £4 each side and the alloy doesn't rot and its easy to shape the ends to the correct profile!!
January 1, 200719 yr Author I made my own using B&Q alloy channel. Bashed over and dremeled open the slit so could slide in ground down stainless flange button socket screws. They look the business and cost £4 each side and the alloy doesn't rot and its easy to shape the ends to the correct profile!! thanx for the info.... the problem is i dont know what an original one looks like so i have nothing to copy from(no dimentions) ? are you a member of the a.c.rd forum ?
January 1, 200719 yr Moderator thanx for the info.... the problem is i dont know what an original one looks like so i have nothing to copy from(no dimentions) ? are you a member of the a.c.rd forum ? No! as i have a 4 stroke xs400. the strips are similar to the xs though. I have added a few pics of what i did, and i could scan the ends for you if you like an PM you? have you tried PGM yamaha? this is the back of the strip although I have flattened them a bit more later these are a comparison with an original got the screws from here. Just ground down the head flat to the washer and use as template to judge the gap of the strip http://www.a2a4.co.uk/acatalog/FLANGE_BUTT...SCREWS_A_2.html
January 1, 200719 yr Author [ quote name='drewpy' date='Jan 1 2007, 08:20 PM' post='38141'] No! as i have a 4 stroke xs400. the strips are similar to the xs though. I have added a few pics of what i did, and i could scan the ends for you if you like an PM you? have you tried PGM yamaha? this is the back of the strip although I have flattened them a bit more later these are a comparison with an original got the screws from here. Just ground down the head flat to the washer and use as template to judge the gap of the strip http://www.a2a4.co.uk/acatalog/FLANGE_BUTT...SCREWS_A_2.html thanks for the information thats more than helpful was the piece of ally a strip before you started shaping it ?
January 2, 200719 yr Moderator No, it was a channel! off the top of my head i think it was 10mm x 20mm x 10mm
January 2, 200719 yr Moderator the c model had a thinner chrome trim that went right around the back of the seat and no tail plastic Drewpy that looks like a good job mate, will have to remember that next time i want some trims, here it is
October 14, 200817 yr lol. this picture is really the original of the bike. Take a look a the cars in the back.
