May 17, 20223 yr Just bought an '09 big bang, my first, as a mini project that needed a good tidy and tlc.Started ok before buying, but hasnt started since I got it back. Had a 22 error code andI replaced the sensor, knowing that wasnt the root.Wasnt till I tried again I heard the pump prime and it fired up, but didnt run long. Rarelyis the pump priming, but when it does it starts.When the pump doesnt prime there is a faint high pitched whine.Any opinions on the best fault finding path? Where to start first? I have an incling it maymay be the ignition, as I've had that with another bike. But this is the first bike I've ownedwith a red key/immobiliser. Are ignition replacements as straightforward because of this?The key is very hard to turn in the old ignition.Thanks in anticipation.
June 6, 20223 yr Author Pump spins when 12v applied. Chased the connections from the ignition, but although the key is v sticky, it seems to be making the right connections. Anyone tell me where the fuel pump relay is? To check the volts there? Thanks On 5/17/2022 at 2:03 PM, Gingerchili said: Just bought an '09 big bang, my first, as a mini project that needed a good tidy and tlc.Started ok before buying, but hasnt started since I got it back. Had a 22 error code andI replaced the sensor, knowing that wasnt the root.Wasnt till I tried again I heard the pump prime and it fired up, but didnt run long. Rarelyis the pump priming, but when it does it starts.When the pump doesnt prime there is a faint high pitched whine.Any opinions on the best fault finding path? Where to start first? I have an incling it maymay be the ignition, as I've had that with another bike. But this is the first bike I've ownedwith a red key/immobiliser. Are ignition replacements as straightforward because of this?The key is very hard to turn in the old ignition.Thanks in anticipation.
June 6, 20223 yr hi Gingerchili, Have you considered joining the R1 forum? a quick google search brings up similar questions within their forum... https://www.r1-forum.com/threads/2009-r1-big-bang-various-advice-needed-please.634158/ Hope that helps.
June 25, 20223 yr Author I did. The post seemed long and rambling. I have put it in a garage to be diagnosed but they are a bit clueless. Trying to find a decent mechanic/bike auto electrician in the glasgow area proving v v frustrating. But thanks.
June 25, 20223 yr Unfortunately I can't help. No knowledge of modern bikes electronics, and have no one to recommend, sorry
