This post is 1169 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
There's only so many switches on the handlebars of any bike, if you're not finding a switch that works the high beam, have you checked to see that the bulb is good?
Mind these wee bikes are 6 volt,,,=  lighting is A/C,, engine running ,,And turn your ignition key to the second position,  [  thats if its a 4 possition ignition],
the bulb is good. i just dont know where the switch is.
How many switches are there on the left grip?
I'm finding pictures that show one or two... If it's two, the right one is on and off, and the left one is low and high. If it's one it's just high & low...
Go into the headlamp shell. Identify the hi beam wire and trace it back. There should be a junction where a wire will lead to a switch
Posted (edited)
that is what ii was gonna do if i couldnt get the answer on here. i dont really want to do it cuz i use the bike every day
there is just the switch for the turn signal and a button for the honk.spacer.png
Edited by Veigar
forgot the picture of the handle
Posted (edited)
Is this a UK bike? Road legal? or a dirt bike used elsewhere? Presumably you've not had it long otherwise you'd know where the switch was.?
if there's no switches on the other handle bar, have you considered asking the previous owner if there was one?
Edited by NE0
LOL, not many people know. A uk moped, ie 50cc bike is not legally required to have main beam. My daughters Aprilia did not have main beam, i converted it because the headlight was shite using kx 125 parts.
So it may well not have main beam.
  • Like 2
  • 1 month later...
I cant get it legal on roads in Iceland unless I have a high beam and I´ve got it legal
So over a month on, have you now got it working? what was the problem.?
Would have been good to know the iceland bit at the start...
I haven´t got it working. I cant find the switch to turn the high beam on.
How many filaments are in the headlamp bulb, if you can't see them, how many solder tags are there on the base of the bulb and/or how many contacts are there in the bulb holder?
If there are two brass contacts in the headlamp holder, then it is wired for both dip and beam.
I must have missed this...
That looks like the control for the right handlebar, what about the left one?
