September 15, 20214 yr Moderator There's only so many switches on the handlebars of any bike, if you're not finding a switch that works the high beam, have you checked to see that the bulb is good?
September 15, 20214 yr Mind these wee bikes are 6 volt,,,= lighting is A/C,, engine running ,,And turn your ignition key to the second position, [ thats if its a 4 possition ignition],
September 17, 20214 yr Author On 9/15/2021 at 11:59 AM, Snakebite68 said: There's only so many switches on the handlebars of any bike, if you're not finding a switch that works the high beam, have you checked to see that the bulb is good? the bulb is good. i just dont know where the switch is.
September 18, 20214 yr Moderator How many switches are there on the left grip? I'm finding pictures that show one or two... If it's two, the right one is on and off, and the left one is low and high. If it's one it's just high & low...
September 18, 20214 yr Go into the headlamp shell. Identify the hi beam wire and trace it back. There should be a junction where a wire will lead to a switch
September 18, 20214 yr Author 28 minutes ago, jimmy said: Go into the headlamp shell. Identify the hi beam wire and trace it back. There should be a junction where a wire will lead to a switch that is what ii was gonna do if i couldnt get the answer on here. i dont really want to do it cuz i use the bike every day 3 hours ago, Snakebite68 said: How many switches are there on the left grip? I'm finding pictures that show one or two... If it's two, the right one is on and off, and the left one is low and high. If it's one it's just high & low... there is just the switch for the turn signal and a button for the honk. Edited September 18, 20214 yr by Veigar forgot the picture of the handle
September 19, 20214 yr Is this a UK bike? Road legal? or a dirt bike used elsewhere? Presumably you've not had it long otherwise you'd know where the switch was.? if there's no switches on the other handle bar, have you considered asking the previous owner if there was one? Edited September 19, 20214 yr by NE0
September 21, 20214 yr Moderator LOL, not many people know. A uk moped, ie 50cc bike is not legally required to have main beam. My daughters Aprilia did not have main beam, i converted it because the headlight was shite using kx 125 parts. So it may well not have main beam.
November 6, 20214 yr Author On 9/21/2021 at 10:02 AM, Cynic said: LOL, not many people know. A uk moped, ie 50cc bike is not legally required to have main beam. My daughters Aprilia did not have main beam, i converted it because the headlight was shite using kx 125 parts. So it may well not have main beam. I cant get it legal on roads in Iceland unless I have a high beam and I´ve got it legal
November 6, 20214 yr Moderator 16 hours ago, Veigar said: I cant get it legal on roads in Iceland unless I have a high beam and I´ve got it legal Would have been good to know the iceland bit at the start...
November 12, 20214 yr Author On 11/6/2021 at 10:39 AM, NE0 said: So over a month on, have you now got it working? what was the problem.? I haven´t got it working. I cant find the switch to turn the high beam on.
November 12, 20214 yr How many filaments are in the headlamp bulb, if you can't see them, how many solder tags are there on the base of the bulb and/or how many contacts are there in the bulb holder? If there are two brass contacts in the headlamp holder, then it is wired for both dip and beam.
November 12, 20214 yr Moderator On 9/18/2021 at 2:18 PM, Veigar said: that is what ii was gonna do if i couldnt get the answer on here. i dont really want to do it cuz i use the bike every day there is just the switch for the turn signal and a button for the honk. I must have missed this... That looks like the control for the right handlebar, what about the left one?
