Meaganhein Posted December 28, 2020 Share Posted December 28, 2020 I am building a 1977 xs750 as a project bike and I’m having electrical issues. Every time I try to get it to turn over the main fuse blows. I have inspected all the wiring from the headlight bucket to the wiring harness and i can’t find any shorts. I also used a multi meter in place of a battery and still had no luck. Does anyone have any idea what this issue might be or even how i can continue to troubleshoot? I’m at a loss. Link to comment Share on other sites More sharing options...
jimmy Posted December 28, 2020 Share Posted December 28, 2020 Is it just when you try to turn it over, or when you turn on the ignition If it is just on the turn over via the electric foot, does it blow fuses with the kickstarter. You will have a short somewhere, so you'll need to start isolating the different circuits and going through everything bit by bit. To save fuses, you can wire in a bulb, and run each wire you're testing through that. The bulb will light up if the circuit is complete indicating the short. 1 Link to comment Share on other sites More sharing options...
blackhat250 Posted December 28, 2020 Share Posted December 28, 2020 Switch ? on handlebar, And " jimmy bet you wish you XS250 Had a short back in the 70"s and went on fire,, == 1 Link to comment Share on other sites More sharing options...
Moderator Cynic Posted December 31, 2020 Moderator Share Posted December 31, 2020 On 12/28/2020 at 4:05 AM, Meaganhein said: I am building a 1977 xs750 as a project bike and I’m having electrical issues. Every time I try to get it to turn over the main fuse blows. I have inspected all the wiring from the headlight bucket to the wiring harness and i can’t find any shorts. I also used a multi meter in place of a battery and still had no luck. Does anyone have any idea what this issue might be or even how i can continue to troubleshoot? I’m at a loss. If it turns over its not a short in the loom its a component issue, either the solenoid or the motor. 1 Link to comment Share on other sites More sharing options...
