DT 175 E gearbox
huxley
This post is 1928 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello All,
After 3 years of owning my DT 175 E I have decided to start work on it properly.
The bike will not start even though it has fuel,a good spark,timing is spot on and crankcase seals have been replaced.This was not my main problem.
I can only get second gear which is why I threw a cover over it 3 years ago.I have now split the crankcases to have a look at the gearbox which all looks o.k,but I have a question.
There are 3 selector forks.One is on a shaft on it own and it moves on the shaft.The other two are on a separate shaft of which one fork moves and the other does not.Is this usual.
Also can you post pictures on this forum ,if so how.
Thanks for any replies
Mark.
Link to comment
Share on other sites
I don't use photobucket since they tried to hold us all to ransom a while back
Postimage.org is my preferred hosting site
  • Like 1
Link to comment
  • Recently Browsing
