Posted March 23, 20196 yr Hi all please could someone help me, are dt175mx crank cases machined as a pair at the yamaha factory or can they be interchangeable. The reason i ask is that i have two sets of cases & would like to interchange them to make one good set Many thanks in advance, kind regards Ronnie
March 23, 20196 yr Hi Ronnie, well I don't see why not, back in the day I swapped out a Triumph crank case just to keep the original engine number still leaked like a right bastard but then they came out of the factory like that! Just make sure they are straight, a large piece of glass helps with that, then at worst use a "SMALL" amount of gasket seal as a belt and braces approach.
March 23, 20196 yr Author 2 hours ago, slice said: Hi Ronnie, well I don't see why not, back in the day I swapped out a Triumph crank case just to keep the original engine number still leaked like a right bastard but then they came out of the factory like that! Just make sure they are straight, a large piece of glass helps with that, then at worst use a "SMALL" amount of gasket seal as a belt and braces approach. Many thanks
March 23, 20196 yr 3 hours ago, slice said: back in the day I swapped out a Triumph crank case just to keep the original engine number still leaked like a right bastard but then they came out of the factory like that! No they didn't
March 23, 20196 yr 1 hour ago, blackhat250 said: Oh Yessss they Diiiidd ...??♂️ Uh uh mister In saying that my new(ish) Bonnie leaks but none of my auld yins did
