This post is 2125 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all please could someone help me, are dt175mx crank cases machined as a pair at the yamaha factory or can they be interchangeable.
The reason i ask is that i have two sets of cases & would like to interchange them to make one good set
Many thanks in advance, kind regards Ronnie
Hi Ronnie, well I don't see why not, back in the day I swapped out a Triumph crank case just to keep the original engine number still leaked like a right bastard but then they came out of the factory like that! Just make sure they are straight, a large piece of glass helps with that, then at worst use a "SMALL" amount of gasket seal as a belt and braces approach.
  • Like 1
Many thanks
No they didn't ;);)
39 minutes ago, jimmy said:
No they didn't ;);)
Oh   Yessss  they Diiiidd ...??‍♂️
  • Haha 1
Uh uh mister
In saying that my new(ish) Bonnie leaks but none of my auld yins did
  • Haha 1
  • Recently Browsing
