November 13, 20187 yr Greetings fellow Yamaha owners, just a quickie to introduce myself, I have only yesterday stepped back in time and bought a 1990 RD350 f2, had a quick spin out today and loved it... a couple of issues to iron out but nothing major, hoping to exchange banter and info on RD's. Hoping for a long and rewarding relationship with my LC Andy T
November 18, 20187 yr Welcome matey. I bought a 4t back in the day and totally missed out on the 2t experience. Plenty of it on here tho
November 19, 20187 yr Moderator On 11/13/2018 at 6:29 PM, Andy T said: Greetings fellow Yamaha owners, just a quickie to introduce myself, I have only yesterday stepped back in time and bought a 1990 RD350 f2, had a quick spin out today and loved it... a couple of issues to iron out but nothing major, hoping to exchange banter and info on RD's. Hoping for a long and rewarding relationship with my LC Andy T And frustration, expense, etc. I warn you now. You will hate it at times and love it all the more. Keep an eye on the coolant and change the plugs if you even slightly think there may be something off. Keep at least a pair of proven plugs for testing too. Enjoy.
November 19, 20187 yr Moderator Andy T, great bikes although I like the YPVS ones Mostly 4T for me atm but would like a 2 smoke
November 26, 20187 yr Author got the frustration frown already! eventually set up the carb sinc but struggling with the oil pump minimum stroke...anyone have a video anywhere on setting this up.....a picture paints a thousand words an all that. Cheers
November 26, 20187 yr Moderator 2 hours ago, Andy T said: got the frustration frown already! eventually set up the carb sinc but struggling with the oil pump minimum stroke...anyone have a video anywhere on setting this up.....a picture paints a thousand words an all that. Cheers Why on earth are you messing with that. Is there something wrong. That pump is as reliable as the sun coming up. They so rarely fail without owner help you should not worry about it.
November 26, 20187 yr Moderator isn't it all about shim washers and feeler gauges, isn't it in the Haynes book?
November 26, 20187 yr Hi andy ", the F2 Its a valve aint it, half faired ?, . And jimmy didnt say what glorious 4T he bought did he ,
December 3, 20186 yr Author Sorry guys, didn't say why I was fiddling with the oil pump, the bike wasn't running right, chucking out loads of smoke, I mean loads...and wouldn't pull the skin of a rice pudding, firstly I had an issue with the throttle cable junction block, one of the throttle cables kept jumping out and the carbs wouldn't stay in sync, sorted that, carbs synced, swapped the jet needles out with the right ones for the bike, and adjusted the oil pump cable so the marks lined up..so far so good, started it up and it run so much better but noticed there was hardly any stroke on the oil pump so I set that up to spec...0.009 thou...happy days until... The bike wouldn't rev to well above 6 thou, checked the power valves and the connector joining the two is well worn the left valve operates as it should ( being connected to the cables) but the right one doesn't move....bugger, so it looks like I now have to renew the power valves. Can anyone shed any light on where I can my hands on a pair of PV's/bushes and seals? Cheers Andy
December 3, 20186 yr Moderator Fowler. Easy. Brace yourself though. The orange seals are 7 quid a pop. The o rings are around a fiver a pop too. It's around 70 quid to overall the pv. Worth it if the bike is nice as the power valve and carb balance are THE critical points to a nice motor. You will never have one without the other. Pv affects the carb and vice versa.
