Posted October 26, 20187 yr Hi everyone! I’m new here and am looking for some help. I’ve got a Yamaha xvs 1100 dragstar and appear to have a tiny oil leak from the rear cylinder that appears to be about the head gasket. How hard is this to strip down and repair and is it possible to repair it myself without needing to have the head skimmed? Or is this possibly a ‘vibration’ issue where the bolts just need re torqued? Please help
October 26, 20187 yr Hi there. Always try the simplest and cheapest possible solution first. Try to nip the bolts up a little. I guess that you mean from the head gasket.
October 27, 20187 yr Moderator I would qualify the above with check the head bolts are tight with a torque wrench rather than nip them up. Don't want to snap or weaken a stud. Head bolts don't vibrate loose unless they were not done up properly in the first place. If its a truly 'tiny' oil leak don't worry about it.
