Posted August 13, 20186 yr hello people, hope you can help me on some parts of the project im very slowly being able to do. this is how to get the top off the top of the forks? no nut to undo? i want to change the oil and seals? i've tried looking for the exact forks that someone has a video or pics on how to.but cannot find the same. if anyone can share a link they know about or help me out here. would really appreciate it. here is pictures off the top part i cannot see how to get out?? also the seal i need to remove. also all the horrid oil that came out..
August 13, 20186 yr Author well i've managed to get the dust seals up, but in picture one the very tops, i don't have a clue what it takes to get into the top to fill the oil, or how to remove the fork part to get he oil seals out? anyone?
August 16, 20186 yr Author ok just in case there is anyone out there that has the time or knowhow . ive got seals and dust seals off, ive cleaned out both bottom tubes of gunk. i now just do not know how to get the top of the forks out? in picture 2? am i in the wrong place to get any answers?
August 16, 20186 yr Do you have a manual for the bike, I assume not. I'm not familiar with it, but can you push the top down a bit to reveal a circlip
August 16, 20186 yr As Jimmy said, push down on the inner thingy with the divot in it and hook out the circlip. Use a piece of cloth over the end to stop it firing across the garage floor..! There is usually a circlip in the bottom section of the fork as well under the dust cap, take the fork clamp off as well it makes it easier to just do one at a time. Don't forget to put the springs back in the right way as well usually tight at the bottom I think, best bet keep them the same way up when you remove them.
August 16, 20186 yr Author thank you jimmy and slice, iv'e tried pushing down on them, but i will try harder this time as i did not want to break anything as i did not know that is how it is done. thank you.
August 17, 20186 yr Justin, this might be of some use to you. NOT the same as yours but all the rest will give you a head's up. https://youtu.be/vrmYJgcGX30
August 19, 20186 yr Hi Justin if you’re having difficulty in taking them apart believe me it’s a lot harder to put them back together. YouTube is your best bet there are plenty of how to clips on fork seal & oil change which will give you a much better picture than anyone here trying to explain
August 19, 20186 yr Yes I know jimmy, but it's so hard to explain it in text compared to video and I can't understand most of what you say anyway you do make a cracking brew though
August 20, 20186 yr On 19/08/2018 at 21:39, Tommy xs said: Yes I know jimmy, but it's so hard to explain it in text compared to video and I can't understand most of what you say anyway you do make a cracking brew though "most of what you say"....Thats an improvement. The first time we met I could see from your coupon that you never understood anything I said ?
August 20, 20186 yr Author thank you to everyone, i pushed even harder with success, i do lots of searches before i bother anyone on here. i do try sort things myself. thank you all, and dont suppose anyone knows the amount of oil in each fork? after searching i see so so many different answers, so i got to thinking it is just under 305ml.? in each fork.. anyone confirm this? or correct amount. thank you in advance oh am i missing something, why does no one have a thank you button?? or i just cant see them.
August 20, 20186 yr Hey justin, be assured you are not bothering anyone, we all like talking bikes, and if we can help we will....no bother Ref fork oil, does that mean you got it apart? and you really need to pick up a manual for it
August 20, 20186 yr Author yes jimmy, all sorted just need to make sure i get the right amount of oil in. i now got service manual and convert what i think into ml. it says us 10.3 us oz now it does not say total or in each fork? so if i got it right that is just under 305ml...?
August 21, 20186 yr It will for each leg A rule of thumb I use is, with the springs removed, I will top the oil up to 150mm below the top of the forks (well I say 6", but you young guns might not know what that is). That 150mm is for a road bike tho' not sure about trail bikes
August 21, 20186 yr Author ok jimmy i might just go by this book, and see what happens when and if i get finished. thanks. im sure to be back for more answers. might as well keep them all in one thread. again thanks
