May 30, 20187 yr After successfully restoring a 1964 Yamaha YDS3, a 1972 Kawasaki H1B, a 1964 Honda CB77 my next project is a 1968 Yamaha YR2C. I have rebuilt the engine and Hydra blasted it and it looks better than new. This bike only has 10,000 miles on the speedo so mechanically was sound and in good condition. It doesn’t even need to go over size just a new set of std rings and a hone to bring it up. I am after an air filter as one is missing and I cannot find one anywhere, I would take 2 as the one I have really needs replacing so if any one could help I would be very appreciative. Starting to dismantle Images of motor after Hydra Blasting and assembly. Edited June 6, 20187 yr by Fast Eddie
May 30, 20187 yr Author I have tried to add photos but they won’t post so it appears that I’m doing something wrong, any ideas? PS I’m using my iPhone to do all this and only have Apple
May 31, 20187 yr I don't use apple so not sure if you can get https://postimages.org You have to register, but it's no big deal Once you upload a picture click on the share button, then copy the hotlinks for forums url. Paste that in your post then remove the 's' in each of the https codes and away you go
June 1, 20187 yr Author I have tried to add photos but they won’t post so it appears that I’m doing something wrong, any ideas? PS I’m using my iPhone to do all this and only have Apple
June 5, 20187 yr wHAT hosting site you using,,,,,, imgur is the bollocks, ,,,,pissbucket is the pits,,
