Posted March 5, 20187 yr Ok folks just a quick question, I am thinking of putting a new set of rear view mirrors on the FJR, I would like to use some with the indicator built in but the ones I want to use are LCD and the ones on the bike (front fairing and rear) are bulbs, so my question is will it matter if I just bung them on and connect them or do I have to use anything else to make them work? I know it's a silly question but I am stumped as to whether it needs a controller in the circuit or not. Thanks folks.
March 5, 20187 yr Moderator if you are keeping the original lamps, I think you will be ok as there is very little resistance in LED. flash git
March 5, 20187 yr Author Thanks mate, I just could not get my head around the LED thing. It's just that the front indicators are really low down on the bike and I thought that a set on the upper part of the bike might make it easier to see where the BMWs can aim.
March 6, 20187 yr Moderator They can sometimes allow power across to the other indicators. You may find you have 4 way flashers. Or depending on how the fjr is wired you may find the rears sulk. May be nothing too.
March 6, 20187 yr Think you'll be OK I connected an led to my indicators just to test the theory and worked fine although I did only try one side If you do get problems change indicator bulbs to led and get led flasher unit, all on eBay
March 7, 20187 yr Author Thanks Cynic that was the problem I thought it might have. Tommy I might give that a go, connect up a couple of LEDs to it and see if the bugger works.
March 7, 20187 yr Moderator 8 hours ago, slice said: Thanks Cynic that was the problem I thought it might have. Tommy I might give that a go, connect up a couple of LEDs to it and see if the bugger works. don't forget to put them the right way round (anode and cathode)
March 8, 20187 yr Moderator On 07/03/2018 at 6:02 PM, drewpy said: don't forget to put them the right way round (anode and cathode) When fitting led's, don't PANiC (P)ositive(A)node(N)egative(C)athode
March 8, 20187 yr Moderator 3 hours ago, Cynic said: When fitting led's, don't PANiC (P)ositive(A)node(N)egative(C)athode Anode that
March 8, 20187 yr 12 minutes ago, drewpy said: Anode that If you say that in a certain way, it sounds like Tommy
