June 5, 20187 yr I might just make it lads, + lassies if there are any. ? ? Sorry ya here of your tumble John, clean wounds, grit your teeth an carry on as normal.
June 5, 20187 yr Moderator 2 hours ago, finnerz89 said: So.... route planned, I've tried to include some good landmarks etc, and some good roads too! Also planned in the tearooms that drew suggested. Screenshot of the route and gpx file attached for those with sat navs YOC_Peak_District_Ride.gpx nice, well done 1 hour ago, 2 Wheels said: I might just make it lads, + lassies if there are any. ? ? Sorry ya here of your tumble John, clean wounds, grit your teeth an carry on as normal. Yay, glad to see you there Pat finnerz, can't seem to download the GPX file mate
June 5, 20187 yr 12 hours ago, finnerz89 said: I was planning a route last night, not fussed about leading. Although I might get left behind otherwise Sent from my SM-G950F using Tapatalk Finnerzs you’ve got no chance of being left behind, me & Jason could only just keep up last year at squires. yer did set a good pace though ? 3 hours ago, finnerz89 said: So.... route planned, I've tried to include some good landmarks etc, and some good roads too! Also planned in the tearooms that drew suggested. Screenshot of the route and gpx file attached for those with sat navs YOC_Peak_District_Ride.gpx That link isn’t working for me, saying it’s been removed or you don’t have right to share on here can you try pm to me Finn
June 6, 20187 yr https://drive.google.com/file/d/1sxAkcdXoMFTbu_6Tn9mCAS4reXN0PnwV/view?usp=drivesdkTry thisSent from my SM-G950F using Tapatalk
June 6, 20187 yr Or thishttps://www.dropbox.com/s/34d0cmbtln0nk4x/YOC_Peak_District_Ride.gpx?dl=0Sent from my SM-G950F using Tapatalk
June 6, 20187 yr Moderator one more thing, Paul and I would like to do the Park run at Bakewell Saturday morning. starts 9am and we should be back by 10am. Is this OK or does peeps want to set off earlier that day?
June 6, 20187 yr one more thing, Paul and I would like to do the Park run at Bakewell Saturday morning. starts 9am and we should be back by 10am. Is this OK or does peeps want to set off earlier that day?Fine by me. We can have a big brekky instead!Sent from my SM-G950F using Tapatalk
June 6, 20187 yr what's the postcode of the campsite? i'll be coming up on Saturday morning (I reckon ill be there by 10am).
June 6, 20187 yr what's the postcode of the campsite? i'll be coming up on Saturday morning (I reckon ill be there by 10am).DE4 2EQSent from my SM-G950F using Tapatalk
June 7, 20187 yr Moderator Depends what time, I have an early mark at work but when I will actually leave may be a bit hit or miss. Prob 6. Im at bugbrooke, J16 m1 On 6/5/2018 at 11:56 PM, Tommy xs said: Finnerzs you’ve got no chance of being left behind, me & Jason could only just keep up last year at squires. yer did set a good pace though ? Too bloody right, that dt changes direction like a housefly, stops like its hit a wall (you have the same front brake as I do on the 250). Everything you lose in a straight line you get back at the first corner.
June 7, 20187 yr Too bloody right, that dt changes direction like a housefly, stops like its hit a wall (you have the same front brake as I do on the 250). Everything you lose in a straight line you get back at the first corner.Well I've just fitted new pads front and rear, brakes are fecking sharp now!Sent from my SM-G950F using Tapatalk
June 7, 20187 yr 2 hours ago, Cynic said: Depends what time, I have an early mark at work but when I will actually leave may be a bit hit or miss. Prob 6. Same here, don't know when I'm leaving but prob be around 3, 3.30 Will definitely look out for ya though. J16 is about half way for me.
June 7, 20187 yr Hi tosspots , am I still on for a Glamping weekend , I'm setting of Saturday morning , hoping to be there early depending weather or not my sat nav pisses me off .?
June 7, 20187 yr Hi tosspots , am I still on for a Glamping weekend , I'm setting of Saturday morning , hoping to be there early depending weather or not my sat nav pisses me off .[emoji6] Yeah I've got a tent for you, have you got a roll mat?Sent from my SM-G950F using Tapatalk
June 7, 20187 yr Moderator managed to download the GPX and also get it to work! got me bits and bobs together, just need to find clothes etc weather looking pretty good too
June 7, 20187 yr no, all I'm bringing with me is my arse and my elbows. ? an air bed would be nice . and maybe a blow up pillar, oh and can you have the tent ERRECT for my arrival ? ta. and don't forget a clean sleeping bag .
