hippyracer Posted February 22, 2017 Share Posted February 22, 2017 Hello Chaps Does anyone have the torques values for a Yamaha MT09, cheers guys. It's been a while since I've been on here so I hope everyone one is good. Link to comment Share on other sites More sharing options...
finnerz89 Posted February 22, 2017 Share Posted February 22, 2017 Google is your friend? Do you mean engine torque? Or what torque to tighten things up to lol Sent from my E6553 using Tapatalk Link to comment Share on other sites More sharing options...
hippyracer Posted February 23, 2017 Author Share Posted February 23, 2017 Sorry, I mean torque values for tightening. Link to comment Share on other sites More sharing options...
jimmy Posted February 23, 2017 Share Posted February 23, 2017 C'mon matey, words are not rationed here Torque values for tightening what? Wheel spindles, Spokes, brake nipples, brake nuts, top fork nuts, yokes, handlebars bolts, tank bolts, rocker box bolts, cam chain tensioners, cylinder heads, barrel base nuts, big end bolts, and on and on and on and on Or everything Tongue firmly in cheek here, but we do need more info bud. 1 Link to comment Share on other sites More sharing options...
KirriePete Posted February 23, 2017 Share Posted February 23, 2017 I normally go with "nipped up", "ooof!" and "oh bollocks!". 2 Link to comment Share on other sites More sharing options...
hippyracer Posted February 25, 2017 Author Share Posted February 25, 2017 Sorry Jimmy, should've been more specific, at the moment I only need the torque value for the bolts for the oil pump cover. Link to comment Share on other sites More sharing options...
finnerz89 Posted February 25, 2017 Share Posted February 25, 2017 Usually something silly like 7 or 9nm. I'd go finger tight then the slightest nip after with a small ratchet. Probably less than a quarter of a turn. Really easy to strip the thread on things like that Sent from my E6553 using Tapatalk 1 Link to comment Share on other sites More sharing options...
jimmy Posted February 25, 2017 Share Posted February 25, 2017 1 hour ago, hippyracer said: Sorry Jimmy, should've been more specific, at the moment I only need the torque value for the bolts for the oil pump cover. No need to apologise bud, tongue in cheek As Finnerz says I would go low. It is only a cover with possibly an O ring to seal**??? If so just ensure you tighten it in a correct sequence. i.e. Finger tight all round then gently tighten opposite fasteners ** Edit: It is a gasket. Looking at the shape of the cover, the key is to ensure a correct sequence Link to comment Share on other sites More sharing options...
hippyracer Posted February 26, 2017 Author Share Posted February 26, 2017 Ok jimmy, thanks for your help Link to comment Share on other sites More sharing options...
