Posted February 6, 20178 yr 78 xt500 i recently installed 12 v headlight always on when running ..led tail light,led turnsignals. regulator, rectifier, and new battery. allwas well all worked good.. no spark now i kick it and neatral light comes on battery un plugged. i tried two new plugs,points clean, condenser tested ok,,,,no killswit just key ignition. neutral lightcomes on whenkeyis on. does that mean its good?points wires are not gounded out...fly wheelis stripped on. can i test stator leaveing it on? money isnot avalable for expensive stator ignition etc ...would a car coil work to see if coil is bad? i bech tested it and it seems close. i have a fluke multimeter... if anyone could please explain to me diagnostics please Edited February 6, 20178 yr by ldwonearth
February 6, 20178 yr Check maybe you have a faulty fuse somewhere, yes a old car coil will work at least to see if you will get a spark but im my opinion either you have a short circuit somewhere or just a fauty fuse Trimis de pe al meu SM-G900F folosind Tapatalk
February 6, 20178 yr Its an illimination process " , start at the plug- and work back to the stator, .and how do you know the ignition switch aint faulty diconect the Black/white ,from that too . and go introduce yoursell, you naughty boy,
