Simon46 Posted January 8, 2017 Posted January 8, 2017 Can I remove rimlocks for innertube on a DT175mx rim as its a counterweight effect and really bounces. I only ride on road. Will the grommet hold the tube in?
Moderator Cynic Posted January 8, 2017 Moderator Posted January 8, 2017 Hasn't affected mine in the slightest. You want to put a grommet in the hole though to keep crap away and water out.
Simon46 Posted January 8, 2017 Author Posted January 8, 2017 Is there a part number.? Got genuine takasago rims.
Moderator Airhead Posted January 8, 2017 Moderator Posted January 8, 2017 the rim tape will hold the tube in and as Cynic said put a grommet in the hole that's left 90480-10068 Its the same as the one in the rear brake plate
Simon46 Posted January 13, 2017 Author Posted January 13, 2017 Did you find after removing rimlocks the road experience was smoother?
Moderator Airhead Posted January 13, 2017 Moderator Posted January 13, 2017 much better without them Simon...no neeed for them at all unless your doing off road with reduced pressures, you can also balance your wheel a little if needed with those weights that clamp around a spoke nipple, dunno if you can still get those though?
Moderator Cynic Posted January 14, 2017 Moderator Posted January 14, 2017 I used plumbing solder. Wheel off the ground. Gently spin it. Let it find its natural rest. Get the solder guestimate at how much but start heavy 20g say? Twist onto a spoke at the highest point. Gently spin again. Trim the lengt of solder or add even ising other spokes as req till the wheel stops randomly. Now weigh the solder and buy the weights or just twist the solder tightly on the spokes. You could also remove the wheel and have it balanced comercially. 1
jimmy Posted January 14, 2017 Posted January 14, 2017 Good, and yet obvious once you hear it, tip, there mate. Never really balanced a bike wheel, and never noticed much of a difference from tyres a shop has fitted
