November 29, 20168 yr Hi guys I keepp having issues with the quote after i quote a reply i cant get rid of it and appears everytime i try to reply in the same thread dunno if its just user errot (my fault) or coding issue Just wanna update my rebuild with quotes in every update Cheers for looking Ride safe
November 29, 20168 yr Moderator confused dot com first you said after i quote a reply i cant get rid of it and appears everytime then you said Just wanna update my rebuild with quotes in every update do you want to quote or not?
November 29, 20168 yr Moderator 55 minutes ago, jimmy said: do you want to quote or not? That is the question its the status quote that we need
November 29, 20168 yr 10 hours ago, jonny5 said: after i quote a reply i cant get rid of it and appears everytime Ride safe Howzzatt ....
November 29, 20168 yr Author 2 hours ago, blackhat250 said: Howzzatt .... Now ive quoted you every time I reply to this thread the quote will keep appearing if you look in my project thread there are blank qoute boxs
November 29, 20168 yr 2 hours ago, blackhat250 said: Howzzatt .... I always quote him as well, but only because I think his patter is great
November 29, 20168 yr Moderator 2 hours ago, blackhat250 said: Howzzatt .... you messed about, I caught you out.... 17 minutes ago, jonny5 said: Now ive quoted you every time I reply to this thread the quote will keep appearing if you look in my project thread there are blank qoute boxs are you using PC or phone?
November 29, 20168 yr 8 minutes ago, drewpy said: you messed about, I caught you out.... Sherbet,,,,,,,,,,,,,,,,,,,,,,,,,,
November 29, 20168 yr Moderator 7 minutes ago, blackhat250 said: Sherbet,,,,,,,,,,,,,,,,,,,,,,,,,, yep, my first record, 2nd was Bohemain Rapsody
November 30, 20168 yr 15 hours ago, jonny5 said: Must be my bloody shitty phone I think I remember something similar when I was using phone browser, maybe try downloading a diff browser. I think I had to log out/refresh page to make it go away. Some people on here use an app - no idea about that though.
November 30, 20168 yr Moderator To delete it completely use the source tab in the top left of the reply options, the layout changes slightly and the quote box turns into lines of text and such. Delete that like you would any other text then swap back using the source toggle again.
