SR 125 Custom rebuild
So ive solved the issue a slight bend in the carb pin ive replaced it and shes puurring like a kitten :D but now i have another issue it seems like the clutch is stuck ill explain i can pull the clutch lever place her in gear (can cycle thru all gears) but when i release the clutch nothing  i think the clutch plates have stuck together maybe anyone got any ideas
Ride safe
  • Replies 63
  • Views 17.2k
  • Frame is finished now      Turned out better than expected    Ride safe
  • My mrs is going mad atm bud she wants her table back but its to cold to be in my shed pmsl  Ride safe
  • Back in the day
    Back in the day
    Hi Jonny 15 hours of grinding I admire your work ethic our local sandblaster does a medium frame and swing arm 80quid including powder coat but I suppose that's the easy way out used to do the even ha
Nope, if the clutch plates stick together you would not be able  to select a gear, as you moved the lever she would be off..
I think its propping (like its permanently pulling the lever) most likely by incorrect adjustment. I bet you could cycle the gears with the engine running without pulling the lever.
Ill take a look
Cynic is spot on, if it goes in gear but does not move it's almost certainly adjusted incorrectly. Or it might have broken the wood ruff key so it spins free.
