Nice one bud Not got a penny to my name ATM so she is on hold for now until i spare a ton to buy the silly little bits i need like bearings n bit but they all add up you know
  • Replies 63
  • Views 13.2k
  • Frame is finished now      Turned out better than expected    Ride safe
  • My mrs is going mad atm bud she wants her table back but its to cold to be in my shed pmsl  Ride safe
  • Back in the day
    Back in the day
    Hi Jonny 15 hours of grinding I admire your work ethic our local sandblaster does a medium frame and swing arm 80quid including powder coat but I suppose that's the easy way out used to do the even ha
Know what you mean Jonny blackhat put it best mate any things possible it's just cash think we ort to do a bit of crowd funding ! Lol doing a car boot this weekend to finance a few more bits given up looking for a it airbox seen a universal enduro one for 20 quid gonna give that a try iam I will pick a more popular bike next time as it 125 stuff is mega rare have a good weekend mate
Time to throw a spanner in the work
The ped i was using for work has started to develop issues (chinnese) so ive had to stop using it and pass her on before she isnt worth a penny so im forced to put the sr back on the road unfinished i wish i had another option but needs must
Engine is back in and all electric are wired up but i this the netural sensor has gone so i cant test fire the engine
Ride safe
So ive managed to resovle the issue with the sensor ive had the engine turning over this morning whoop whoop
But i cant get any dash lights highbeam, nuetral or indicators but i am getting the back light so ihave got power to it
Ride safe
What a bummer jonny,    ,  no other cheap peds on gumtree . ?
Jonny stay away from the chinky shit I bourght a Suzuki 100erz for my 14 year old boy It hadn't been run for 10 years but some new fuel and a couple of kicks and it was ticking over a year done the line it's still trucking ! Would prefer a push bike to a chiinky bike good luck bro
Not close by bro and couldnt afford a cheap one even if i didnt pay my bills
Needs must bud only had 400 budget and i couldnt wsit as i delivery pizza for a living so everyday. I was. Losing 120 so didnt have a choice really
I did a little work on the chinky today the diaphram in the carb had split and piston rings are going she still runs well but ill pass her on
Just gunna pop some Pics of the sr in photobucket shes looking bloody good considering she is half finished
Just gotta put a new tube in front wheel and some fuel and she be running
Forgot the exaust
Ride safe lads
WAYHAY. SR style B) pitza   soon ,,
Pmsl bro
looking good tho isnt she very surprised actually
Bloody hell jonny that's one hell of a top box reminds me of one I knocked up for a ap50 nearly 40 years ago while working at a cider canning factory at the end of the day the  boss put all over or under filled cans on a big pallet and you could help yourself !
Hi guys
So she is all bk 2g4 having a little engine trouble the revs keep increasing on idle and wen i give some throttle the revs dont die bk down just revs higher and higher
The throttle isnt sticking niether is the slider in the carb any ideas
Thanks for poping in
Didnt remove the manifold, hasnt been fuel starved, fuel flow is good and yea the fuel cap is venting fine its confusing the shit out of me why its climbing maybe its trying to idle very high possibly thats y it keeps climbing
My gasket on the exhaust needs doing but wouldnt have thought that could be a cause
On Thursday, December 15, 2016 at 7:03 PM, Airhead said:
is there ckearance on the exhaust valve tappet when it's not on cam?
How would i go about checking for clearance ?
Take the cam cover off and use a feeler gauge to check your gaps, easy and straight forward. Should take about an hour to do.
Clearance has been checked and all fine no air leaks i can find even removed throttle cable and still revs its nut off its driving me crazy
I even removed the air filter placed my hand over air intake and she dies so deffo dont think its a air leak could it be sonething broken in the engine so the piston is running freely with no resitance
As its happened before to somebody else. How much fuel is in it?
Its not unknown for the floats to stick causing the engine to run out of fuel, as it runs down slow the engine revs can rise.
If you put finger in the back of carb, lift the slide ,and let it go,  does it return [ clunk]  to the bottom, and screw outthe idle screw,. you should see slide go as low as thers virtually no gap,,  then crew air screw in fully,  see what happens,
