SR 125 Custom rebuild
6 minutes ago, Back in the day said:
Looking good Jonny thourght you were getting the professionals in to do the tank
My brother in laws brother in law is gunna do it for me He told me to prime it to keep costs down and he will do too coat for next to nothing dont think he wanted to clean his gun twice lol
  • Replies 63
  • Views 16.4k
  • Frame is finished now      Turned out better than expected    Ride safe
  • On Monday, November 28, 2016 at 0:17 PM, drewpy said: Well done mate I have got to say sr was never a bike I wanted to own but I love the look of the end result bike what a transformation
  • Back in the day
    Back in the day
    Hi Jonny 15 hours of grinding I admire your work ethic our local sandblaster does a medium frame and swing arm 80quid including powder coat but I suppose that's the easy way out used to do the even ha
4 minutes ago, Back in the day said:
Well your cracking on at a good pace looking forward to seeing the finished results bud
Will start to slow now bud I've run out of money lol
I know that feeling your doing great on a shoestring budget think there is  a tv series in you mate Jonnys kitchen table bike build on a shoe string! Way better than that Henry cole bloke !
I wish bud would have her finished by now
I didn't manage to get much done today apart from excavate the long lost kitchen table only issue was some petrol had melted the plastic tablecloth to the table so I had to strip it and revarnish it before the mrs come home from work
But I did manage to start work remodelling the seat was gunna buy one so thought I might as well have a crack at reshaping the old seat
20161202_175633_zpsbpcti1ep.jpgI'm going to cover the seat with brown leather and do a diamond stitch pattern on the face of the seat
Ride safe
Nah bud she didn't have a bloody clue lol this weekend will be fun gunna get the engine bench tested and start stripping back the loom as I wanna get rid of indicators relays ect
Enjoy you weekend bro
Ride safe
Evening guys
Hows it going didn't manage to the loom today got cracking on with the rear mudguard was really rusty and had a divet in it that need to be beaten out
Also frame had its final coat of laquer today so she is ready to start having bits put back on
I did start to clean up the front forks but both seals are on the verge on blowing so gunna do that before the clean up and painting
Ride safe
Well done, what you rubbing down with,   flapper disc,   its removed that rust well ,
I'm using wire brush heads on my drill and angle grinder
Evening guys
I've run into a little road block after starting work on the rear swing arm I've found some bad corrosion on the underside
I've was wondering if anyone would know if I could cut away the whole bottom panel or is it structurally integral and cheaper to replace then have repaired?
Ride safe
Looks to me like  a welded plate, so for what it's worth cut it off and take it to your local welder and get him to replace the plate with some nice shiny steel. Better still leave it on and get him to remove it and then he can see what needs to be replaced, yes by the way almost certainly structural.
I can replace it for £30 do you think it would be cheaper then the repair ?
Or I might get a 250 swing arm then I could fit a larger rear wheel on
Cheers drewpy
Can get one off a 250 for same price do you know if it would fit I've done some research and looks like most of there parts are pretty much interchangeable but I'm not 100% sure on that and dont wanna pay postage from the States on sumit That dont fit
Cheers peps
Ride safe
11 hours ago, jonny5 said:
Cheers drewpy
Cheers peps
Ride safe
not sure mate, with imports you are subject to customs charge and if not pre paid, post office will charge £8 for collecting the money
Just checked online I would need to pay 20% vat and 3.7% custom charge so probably not a good idea as if probably need a wheel from across the pond too
Hi Jonny Got fed up trawling for my hens teeth  airbox tonight dps breakers somerset have a swinging arm and a guy selling sr bits gumtree parts I think if you look hard uk will come up trumps way more sr bits than flapping it airboxes  in blity good luck bud rich
 01634 242018 bike shop in Kent solid no rot with good bushes that don't need changing 25 quid 8 quid post grab it before someone in the us buys it lol! I saw lots of really rotten ones going for stupid money why anyone would buy a swing arm that needs welding is beyond me ! this one looks sound mate he might have a wheel as well you never know am off to work now bud cheers rich
