Three white wires
1 hour ago, Spike101uk said:
Yea I knew it was fuel after what u said, my point was is thr carb cleaner sposed to pour straight  out inlet or should it dissappear and go through carb to cylinder, as it seemed carb didn't let it in
only lets it in on the inlet stroke
  • Replies 42
  • Views 14.3k
  • I have news, and it's good, I drained the carb float bowl and gave it a few light ish taps and and refilled and then started and it worked then didn't,  after a lot of looking around I found one wire
  • Thank F**k for that
  • neversaydie
    neversaydie
    Ive always found these two links to be useful sources of info for fault finding. They are not copyright, they are freely available http://www.electrosport.com/technical-resources/library/diagnosi
I have news, and it's good, I drained the carb float bowl and gave it a few light ish taps and and refilled and then started and it worked then didn't,  after a lot of looking around I found one wire between tci and coil was slightly broke so only worked some of the time, that's been replaced and now have constant spark and fuel entering re cylinder ,  thank you so much for all your help I've learnt a lot about my bike.
Solved
